1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy
To: Michael Davidsaver <[email protected]>, [email protected]
Date: Wed, 13 May 2015 11:52:19 -0700
On Wed, May 13 2015, Michael Davidsaver <[email protected]> wrote:
> On 05/13/2015 01:06 PM, Jameson Graef Rollins wrote:
>> On Tue, May 12 2015, Michael Davidsaver <[email protected]> wrote:
>> Hi, Michael.  I should have mentioned that I did try doing this at your
>> suggestion, but wasn't able to devine anything useful myself.  I'm not
>> quite sure what I'm looking for, though:
> The error is coming from:
> http://bazaar.launchpad.net/~epics-core/epics-base/3.14/view/head:/src/libCom/osi/os/posix/osdMutex.c#L108
> If the unlock fails then cantProceed() is called, which calls
> epicsThreadSuspendSelf.  The posix version of which ultimately calls
> pthread_cond_wait().
> http://bazaar.launchpad.net/~epics-core/epics-base/3.14/view/head:/src/libCom/osi/os/posix/osdEvent.c#L75
Thanks Michael!  This sounds somewhat promising.
> From the top two frames this could be either thread #1 or #4.  Can you
> post the full stacks?
This program utilizes two processes: a "main" daemon process and a
"worker" sub-process.  The daemon holds the PCAS, while the worker uses
pyepics to do the work.
Attached is the gdb bt output for the threads of both the "MAIN" and the
"WORKER" for one of these wedged nodes.  Like I said, I'm pretty sure
the problem is in the PCAS, so I think the problem is in the MAIN, but I
include the WORKER bt for completeness.
I don't actually have a wedged node right now, so I can't get any more
info until it happens again.  If there's some other gdb info I can
retrieve next time this happens, please do let me know.
jamie.
Attachment: epicsMutex_pthread_error-SEI_HAM6
Description: Binary data
Attachment: signature.asc
Description: PGP signature
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
"epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Prev: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Next: Re: EPICS training sessions Bob Gunion
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
Next: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
