1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: problem about IPServerPort using ASYN
To: EPICS <[email protected]>
Date: Wed, 13 May 2015 11:06:31 +0800 (CST)
Recently I want to set up a TCP server and make it to a virtual device by using EPICS. The example testIPServerApp runs normally which doesnot use the devicesupport, but when I use the drvAsynIPServerPortConfigure and start the IOC, I have the problems as followed.
dbLoadDatabase "dbd/AB300.dbd"
AB300_registerRecordDeviceDriver pdbbase
## Load record instances
#dbLoadRecords("db/xxx.db","user=yuHost")
dbLoadRecords("db/devAB300.db","P=AB300,R=,L=0,A=0")
drvAsynIPServerPortConfigure("L0","10.40.18.201:5200",2,0,0,0)
cd /home/yu/ioc/ab300/iocBoot/iocAB300
iocInit
Starting iocInit
## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$
## EPICS Base built Aug 10 2014
2015/05/07 13:59:52.336 L0 devGpib registerSrqHandler failed asynManager:getInterruptPvt Driver does not support interrupts on interface asynInt32
## Start any sequence programs
#seq sncxxx,"user=yuHost"
epics>
The server can't set up normally, and the communication is failed. I don't understand what these words mean "L0 devGpib registerSrqHandler failed asynManager:getInterruptPvt Driver does not support interrupts on interface asynInt32".
I wonder someone who can help me to sovle the problem. Thanks so much!
Best regards!
RE: problem about IPServerPort using ASYN Mark Rivers
Prev: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
Next: RE: problem about IPServerPort using ASYN Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS training sessions Bob Gunion
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
