1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy
To: [email protected]
Date: Tue, 12 May 2015 16:29:59 -0400
On 05/12/2015 02:48 PM, Jameson Graef Rollins wrote:
> The most troubling aspect of the problem is that the actual PVs remain
> active, while the underlying process freezes.  Existing PV subscriptions
> remain valid and the PCAS continues to respond to new requests.  However
> the database is no longer being updated so all values are bogus.  In
> other words, we have **no external indication that the process is in a
> frozen state**.
Since the process continues running can you attached gdb and get stack
traces?  This should show the place where the _main_ thread has stopped.
> $ gdb
> (gdb) attach <pid>
> (gdb) thread apply all backtrace
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Prev: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Wang Xiaoqiang (PSI)
Next: problem about IPServerPort using ASYN bella
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Next: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
