1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy
To: Jameson Graef Rollins <[email protected]>
Cc: Epics <[email protected]>
Date: Tue, 12 May 2015 20:18:56 +0000
Hi Jamie,
Maybe a minimal example representing the program logic could help the debug.
> On 12 May 2015, at 20:48, Jameson Graef Rollins <[email protected]> wrote:
> On Mon, Feb 23 2015, Jameson Graef Rollins <[email protected]> wrote:
>> Hi, folks.  We recently saw the following error thrown from one of our
>> dual pyepics/pcaspy applications:
>> epicsMutex pthread_mutex_unlock failed: error Invalid argument
>> epicsMutexOsdUnlockThread _main_ (0x2999f20) can't proceed, suspending.
>> After this error was thrown the application became completely
>> unresponsive and had to be manually killed.
>> I'm not sure which interface the error came from: pcaspy or pyepics.
>> We're running the following versions of the relevant packages:
>> epics-base 3.14.12.2
>> pyepics 3.2.0
>> pcaspy 0.4.1
>> Any idea what could have caused it?  I've only found one reference to a
>> similar issue with a gateway (base 3.14.9, gateway 2.0.3.0) [0].  A
>> follow-up bug report implied that the issue might have been addressed in
>> base 3.14.11 [1], which precedes the version we're using.
>> Any help would be much appreciated.  Thanks so much.
>> jamie.
>> [0] http://www.aps.anl.gov/epics/tech-talk/2009/msg00021.php
>> [1] https://bugs.launchpad.net/epics-base/+bug/541356
> Hi, all.  I need to resurrect this thread, since we haven't been able to
> fix this issue, and it continues to cause headaches.
> We're now fairly confident that the problem resides in the pcaspy
> interface.  We have evidence that it is triggered by a long running
> subscription to the pcaspy server being severed abruptly.  That doesn't
> consistently trigger the issue, though, as we have dozens of these
> processes but only one will fall into this state when the archiver is
> restarted.  We're also still unable to replicate the problem in a
> controlled environment.
> The most troubling aspect of the problem is that the actual PVs remain
> active, while the underlying process freezes.  Existing PV subscriptions
> remain valid and the PCAS continues to respond to new requests.  However
> the database is no longer being updated so all values are bogus.  In
> other words, we have **no external indication that the process is in a
> frozen state**.
> If I could either figure out some way to reliably re-create the problem,
> or to at least get better debug messages about where in the stack the
> problem is occurring, I could maybe make some headway.  Unfortunately
> it's not feasible to run all of our deployed processes under valgrind to
> try to catch one of these instances when they pop up.
> Can someone who knows the pcaspy internals help me figure out where I
> should poke?
> jamie.
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Prev: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Next: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
