Benoit, Your suggestion led me to the solution. The problem was in CSS's ADDR list settings, which apparently are not listening to the same environment variables that CA is using. Thanks so much! To be clear: CSS > Preferences > CSS CORE > EPICS > addr list Make sure local ip (127.0.0.1) and your broadcast IP are in the list. Broadcast IP was calculated using this calculator: http://jodies.de/ipcalc xx.xx.19.0/24 did not work for me. On Thu, May 7, 2015 at 1:10 AM, Benoit <[email protected]> wrote:
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
