Hi Ralph,
I just tested 3-15.2-rc1 on WIN32, and found some problems.
My setup is using a Linux file server that holds a single tree, in which I build for all architectures (Linux, WIN32, Cygwin, vxWorks, Darwin). I don’t know if that configuration
has any bearing on my results.
I found that parallel make does not work on any WIN32 architectures (win32-x86, win32-x86-static, windows-x64, windows-x64-static). The symptom is that “make” goes to using 100%
of a core at some point during the build of libCom, and no further output occurs. This was the output of “make –j” at the point where it hung building win32-x86-static:
perl -CSD H:/epics/base-3.15.2-rc1/bin/win32-x86-static/mkmf.pl -m epicsUnitTest.d -I. -I../O.Common -I. -I../../../src
/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../s
rc/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../.
./../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../
../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src
/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libC
om/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I..
/../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../sr
c/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
epicsUnitTest.d ../../../src/libCom/misc/epicsUnitTest.c
"make" was using 100% of one core at this point, and nothing further happened. I had to kill it with ^C.
On base 3.14.12.5 win32-x86-static and windows-x64-static work fine with parallel make, while win32-x86 and windows-x64 do not. The failure for the archs that don’t work is an
error reporting a missing .lib file I believe.
The performance is also significantly worse, even for non-parallel make. These are times I measured today for building the win32-x86-static architecture:
3.14.12.5 parallel make 6 minutes
3.14.12.5 non-parallel make 22 minutes
3.15.2-rc-1 non-parallel make 46 minutes
So it is taking 7.5 times longer to build 3.15.2-rc1 than 3.14.12.5. This is mostly because I can use parallel make, but even non-parallel make is over twice as fast on the older
version.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Ralph Lange
Sent: Thursday, April 30, 2015 2:16 AM
To: EPICS Tech-Talk
Subject: Base R3.15.2-rc1 release
The (first) release candidate for the next release of the EPICS Base
3.15 series 3.15.2-rc1 is now available for download and testing. Please
read the Release Notes to see what's new in this release.
http://www.aps.anl.gov/epics/base/R3-15/2.php
Please test - especially if you have less widespread OS/architecture
setups that you can test on - and report feedback and any problems you
encounter here on the tech-talk list.
Note that some support modules may require changes to build properly
with this release, so check with a module author to see if they have a
3.15 version available if you encounter problems.
If no major issues arise with this code, the final 3.15.2 release will
be created in the second week of May. Thanks to everyone who has
contributed towards this release, and especially to the other core
developers for all their work.
~Ralph
