1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Error while running ioc...
To: [email protected]
Date: Sat, 25 Apr 2015 19:22:55 -0600
Hello All again,
Well I have been able to run a bunch of things now, but I'm running into an error I just don't quite understand.  After doing makeBaseApp for a device I'm attempting to get running, upon running ./st.cmd it says:
Successfully locked memory using mlockAll
#!../../bin/linux-x86_64/testDevice
## You may have to change testDevice to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","ioctestDevice")
epicsEnvSet("TOP","/usr/local/epics/spectrometer/test")
epicsEnvSet("SNCSEQ","/usr/local/epics/synApps_5_8/support/seq-2-2-1")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
cd "/usr/local/epics/spectrometer/test"
dbLoadDatabase "dbd/testDevice.dbd"
testDevice_registerRecordDeviceDriver pdbbase
Warning: IOC is booting with TOP = "/usr/local/epics/spectrometer/test"
          but was built with TOP = "/usr/local/epics/spectrometer/test2"
## Load record instances
dbLoadTemplate "db/user.substitutions"
dbLoadRecords "db/dbSubExample.db", "user=root"
## Set this to see messages from mySub
#var mySubDebug 1
## Run this to trace the stages of iocInit
#traceIocInit
cd "/usr/local/epics/spectrometer/test/iocBoot/ioctestDevice"
iocInit
Starting iocInit
## EPICS R3.15.2-pre1 $Date: Tue 2015-04-14 10:14:29 +0200$
## EPICS Base built Apr 19 2015
## Start any sequence programs
#seq sncExample, "user=root"
filename="../../../src/ioc/db/dbCa.c" line number=759
dbCa: eventCallback Logic Error
epics> filename="../../../src/ioc/db/dbCa.c" line number=759
This continues till I kill it.  I'm still attempting to figure it out, but I have been stuck for hours on it.
I have a feeling I'm not defining something in the code correctly...
Chris
Re: Error while running ioc... Johnson, Andrew N.
Prev: RE: medm command not working... Mark Rivers
Next: Re: Error while running ioc... Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
