1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: medm command not working...
To: Chris Eckman <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 25 Apr 2015 19:16:30 +0000
You need to put [EXTENSIONS]/bin/[ARCH] in your PATH, where [EXTENSIONS] is where you build the EPICS extensions and [ARCH] is your EPICS host architecture.  For example
/usr/local/epics/extensions/bin/linux-x86_64
From: [email protected] [[email protected]] on behalf of Chris Eckman [[email protected]]
Sent: Saturday, April 25, 2015 1:43 PM
To: [email protected]
Subject: medm command not working...
Hello All,
I have installed medm with make and make install.  There were no errors, when I attempt to run the command, "medm" it says, "No command 'medm' found,"  I really could not find much online about it so I'm asking the EPICS group...
Thanks!
Chris
medm command not working... Chris Eckman
Prev: medm command not working... Chris Eckman
Next: Error while running ioc... Chris Eckman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
