1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Regading Conflicting libraries for CA Lab & labCA
To: Mark Rivers <[email protected]>, Rahul Jain <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 22 Apr 2015 08:19:43 -0700
I think what you ultimately want is to avoid is having
labCA and calab/labview (or other epics CA clients)
using different versions of the epics base libraries
(ca.dll, Com.dll).
-> make sure all your epics clients are built against
    the same epics base version
-> have PATH point to the DLLs of this base version
this way you ensure all clients work correctly.
If you must use different versions of base for labCA
and calab then you must make sure the PATH points
to (and only to) the correct version when you use either
labCA or calab. Having multiple versions of ca.dll/Com.dll
in your PATH can potentially cause trouble.
HTH
- Till
On 04/22/2015 05:18 AM, Mark Rivers wrote:
How did the EPICS CA Lab installation find those DLLs from labCA?  Is that directory in your PATH?  If so, try removing it from the PATH.  Where are you trying to install EPICS CA Lab?
From: [email protected] [[email protected]] on behalf of Rahul Jain [[email protected]]
Sent: Wednesday, April 22, 2015 7:10 AM
To: [email protected]
Subject: Regading Conflicting libraries for CA Lab & labCA
Dear Sir,
I want to install EPICS CA Lab (an EPICS channel access interface for
LabVIEW™) on a win-x86 PC, on which labCA (an EPICS channel access
interface for Scilab and Matlab) is already installed. I am getting
following warning messages while installation:-
To avoid incompatible library mixes installation has been stopped.
Conflicting libraries:
f:\bnm\EPICS_win32\labca_3_0_beta\bin\win-x86\caRepeater.exe
f:\bnm\EPICS_win32\labca_3_0_beta\bin\win-x86\ca.dll
f:\bnm\EPICS_win32\labca_3_0_beta\bin\win-x86\Com.dll
Please move,remove or rename conflicting libraries.
I want CA Lab (LabVIEW™) & labCA (Scilab and Matlab) both to be there on
my PC. Please guide me in this regard.
With best regards
Rahul Jain
RRCAT, Indore (INDIA)
Regading Conflicting libraries for CA Lab & labCA Rahul Jain
RE: Regading Conflicting libraries for CA Lab & labCA Mark Rivers
Prev: Re: Misunderstanding of epid record ODEL field? Pearson, Matthew R.
Next: RE: related to conversion Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Regading Conflicting libraries for CA Lab & labCA Mark Rivers
Next: Re: Regading Conflicting libraries for CA Lab & labCA Shen, Guobao
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
