1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS installed, making ioc, not working...
To: Chris Eckman <[email protected]>
Cc: [email protected]
Date: Mon, 20 Apr 2015 11:58:08 -0500
You need to do the following as well:
makeBaseApp -i -t example test
At that point, you should have iocBoot directory (you will still have to compile the IOC).
On Apr 20, 2015, at 11:47 AM, Chris Eckman wrote:
Hello All,
I have recently installed EPICS on my laptop and it *seems* to be installed correctly and work, when I do:
mkdir test
cd test
makeBaseApp -t example test
It creates folders and files that are:
configure  Makefile  testApp
Running make will create:
bin  configure  db  dbd  include  lib  Makefile  testApp
The blue represents the folders (you know, as you would see it in terminal, also I hope it shows up for people)...
Maybe I'm mistaken, but I thought there should of been an "iocBoot"  with an st.cmd in it, but I did not see it, even checking in the folders...
Anyone know what is happening?
I know when I run st.cmd it will run the IOC and put me into EPICS world.  But I need to get there first...  Thanks!
Thanks!
Chris
EPICS installed, making ioc, not working... Chris Eckman
Prev: EPICS installed, making ioc, not working... Chris Eckman
Next: Re: EPICS installed, making ioc, not working... Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: EPICS installed, making ioc, not working... Mooney, Tim M.
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
