1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Installing EPICS... error
To: [email protected]
Date: Fri, 17 Apr 2015 22:39:29 -0600
Hello all EPICS people,
I've been attempting to install EPICS to my computer running Linux Mint, I am using an link:
Well I get to the 2nd instruction, namely "install base" and it says the following when I make:
make -C ./configure install
make[1]: Entering directory `/home/chris/Documents/EPICS/base-3.15.1/configure'
perl -CSD ../src/tools/makeMakefile.pl O.linux-x86 ../..
Cannot create O.linux-x86/Makefile at ../src/tools/makeMakefile.pl line 41.
make[1]: *** [O.linux-x86] Error 2
make[1]: Leaving directory `/home/chris/Documents/EPICS/base-3.15.1/configure'
make: *** [configure.install] Error 2
This says that the perl command is not working for some reason, however I know I installed perl.  Does anyone know why this is giving me an error or have you run into this issue yourself?  Please help,
Thank you,
Chris
Re: Installing EPICS... error Johnson, Andrew N.
Re: Installing EPICS... error Pete Jemian
Prev: EDM properties dialog issue Mesa Mike
Next: Re: Installing EPICS... error Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EDM properties dialog issue Mike Westfall
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
