1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: epicsQt and QWT6
To: John Dobbins <[email protected]>, EPICS mailing list <[email protected]>
Date: Fri, 17 Apr 2015 15:51:16 -0700
John,
For the Australian Synchrotron epicsqt, make sure to set your environment correctly.
In particular, look at the QWT_INCLUDE_PATH envvar.
$ cat > SourceMe <<EOT export EPICS_BASE=~epics/base-3.14.12.4 export EPICS_HOST_ARCH=linux-x86_64 export QWT_INCLUDE_PATH=/usr/include/qwt # On Ubuntu 14.04 export EPICSQT_DIR=~epics/extras/3.14.12.4/epicsqt/2.8.1 export LD_LIBRARY_PATH=$EPICSQT_DIR/framework/designer:$EPICS_BASE/lib/$EPICS_HOST_ARCH export QT_PLUGIN_PATH=$EPICSQT_DIR/framework EOT $ . SourceMe # setup your environment
Of course after this you have to run 'qmake' and 'make' in the source directory.
Cheers,
Emmanuel Mayssat
http://www.epicsqt.org
To: [email protected]
Subject: epicsQt and QWT6
Date: Fri, 17 Apr 2015 19:48:55 +0000
All,
I am taking my first look at epicsQt and caQtDM. I built epicsQt with Qt-4.8.5 and Qwt-5.2.3. All peace and happiness. Then I looked at caQtDM and see that the latest version, 3.9.1,  is calling for Qwt 6.0.1
I built qwt 6.0.1 but haven't been able to build epicsQt against it. For reasons I don't understand it won't find the qwt lib.
So I'm just wondering if any knows that this (epicsQt with Qwt 6) should work before I bang my head some more.
John Dobbins
Cornell University Laboratory for Accelerator-Based Sciences and Education
epicsQt and QWT6 John Dobbins
Prev: Re: epicsQt and QWT6 Zenon Szalata
Next: EDM properties dialog issue Mesa Mike
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
