Hi Dirk,
I finally got everything working by using your suggestion for the compress records and setting the terminator properly.
Thanks for all your suggestions.
Tony
On 13.04.2015 16:15, Anthony Pietryla wrote: Dirk,
I tried a form of that where the first (horizontal) record used I/O intr and forward linked to the vertical record. I would get one value in each waveform then I would receive the error about “surplus input”.
In that case, you probably have the wrong terminator. With the right terminator, each 'in' should read one line. Dirk Tony
On Apr 13, 2015, at 9:05 AM, Dirk Zimoch <[email protected] <mailto:[email protected]>> wrote:
Hello Anthony,
In principle you can also use "I/O Intr" for the two longin records. They should trigger for each line. But I cannot guarantee this.
record (longin, "$(P)$(R)TBT_Horizontal_tmp") { field (DTYP, "stream") field (INP, "@spark.proto getTBT_X $(PORT)") field (SCAN, "I/O Intr") field (FNLK, "$(P)$(R)TBT_Horizontal") }
Similar for vertical.
Terminator = "\n";
# only trigger reading getTBT_XY { out "TBT_XY 3"; }
# processes the I/O Intr records once for each input line getTBT_X_line { in "%i %*i"; }
getTBT_Y_line { in "%*i %i"; }
Unfortunately EPICS isn't very good at multi-dimensional arrays.
Dirk
On 13.04.2015 14:59, Anthony Pietryla wrote:
Hi Dirk,
Thank you for your reply. Unfortunately, there are many more than three rows to read, up to 256k samples/channel. I used a value of three for my debugging.
One suggestion I received was to read everything into one huge array and use an asub record to parse the values.
Thanks, Tony
On Apr 13, 2015, at 3:54 AM, Dirk Zimoch <[email protected] <mailto:[email protected]> <mailto:[email protected]>> wrote:
Hello Anthony,
For waveform records StreamDevice repeats the format for each element and optionally reads a separator in between. While this allows to read a row, it cannot read a column. And it probably does not work with redirection (I have never tried).
This makes it a bit complicated to read your device. But hopefully not impossible. You need a few more records.
I understand that the reply always consists of 3 rows. Then I would try the following:
Have two longin records, one for X and one for X. Redirect to these records as you do now, but do it 3 times:
Terminator = "\n"; getTBT_XY { out "TBT_XY 3"; in " %(\$1TBT_Horizontal_tmp)d %(\$1TBT_Vertical_tmp)d"; in " %(\$1TBT_Horizontal_tmp)d %(\$1TBT_Vertical_tmp)d"; in " %(\$1TBT_Horizontal_tmp)d %(\$1TBT_Vertical_tmp)d"; }
This processes the two longin records 3 time each. For the waveforms use two compress records and do a FLNK from the longin records to the compress records:
record (longin, "$(P)$(R)TBT_Horizontal_tmp") { field (FNLK, "$(P)$(R)TBT_Horizontal") }
record (compress, "$(P)$(R)TBT_Horizontal") { field (INP,"$(P)$(R)TBT_Horizontal_tmp") field (ALG, "Circular Buffer") field (NSAM,"3") }
The same for Vertical.
I am not quire sure about the compress record settings. Maybe you need to try a bit. Maybe you may want to write to the .RES of the compress before starting. In that case you can use additional seq records.
Hope this helps.
Dirk
On 09.04.2015 23:01, Anthony Pietryla wrote:
I have a device which uses SCPI protocol and returns sets of waveforms in columns where I can request how many rows to return. For instance I can query the device for 3 values of position data and it will return 2 columns (X & Y) and 3 rows. I want to read the columns into separate waveform records. I am having problems with the protocol file for which I need help.
The database records and the protocol file are listed below. When I process the record only the first values (first row of data) are written to each record. With asyn debugging turned on the console shows all three sets of data:
epics> 2015/04/09 13:52:36.877 L0 wrote TBT_XY 3
2015/04/09 13:52:36.878 L0 read 2000 6000 7143 4286 4286 1429
caget shows only the first value stored:
caget -# 5 B:Spark:TBT_Horizontal B:Spark:TBT_Horizontal 5 3333 0 0 0 0
caget -# 5 B:Spark:TBT_Vertical B:Spark:TBT_Vertical 5 -1111 -3333 0 0 0
******************* The protocol file has:
getTBT_XY { Separator = "\n"; out "TBT_XY 3"; in " %(\$1TBT_Horizontal)d %(\$1TBT_Vertical)d"; ExtraInput = Ignore; }
************** The database records are:
record(waveform, "$(P)$(R)TBT_Horizontal") { field(DESC, "TBT Horizontal") field(DTYP, "stream") field(INP, "@spark.proto getTBT_XY($(P)$(R)) $(PORT)") field(NELM, "262144") field(EGU, "um") field(FTVL, "LONG") }
record(waveform, "$(P)$(R)TBT_Vertical") { field(DESC, "TBT Vertical") field(DTYP, "Soft Channel") field(NELM, "262144") field(EGU, "um") field(FTVL, "LONG") }
******************** When I comment out the “ExtraInput = Ignore;” line in the protocol file I get error messages:
2015/04/09 15:53:58.170 L0 wrote TBT_XY 3
2015/04/09 15:53:58.170 L0 asynOctetBase interrupt 2015/04/09 15:53:58.171 L0 read 3333 -1111 -3333 -5556 -2000 0
2015/04/09 15:53:58.271 L0 B:Spark:TBT_Horizontal: 29 bytes surplus input "<0a> -3333 -5556<0a> -200..." 2015/04/09 15:53:58.271 L0 B:Spark:TBT_Horizontal: after 13 bytes: " 3333 -1111"
-- Anthony Pietryla Principal Controls Engineer Advanced Photon Source Argonne National Laboratory
Phone: 630-252-7430 Fax: 630-252-6123
