Subject: |
Gentec S-link power meter problem with ending I/O interrupt measurement |
bohmm <[email protected]> |
To: |
Tech talk <[email protected]> |
Date: |
Tue, 14 Apr 2015 11:07:29 +0100 |
Hello,
I am an EPICS newbie and trying to implement statistics functions for
our energy meter. Our laser system is running at 10 Hz and the energy
meter has to catch every pulse energy/power value for the statistics to
be computed properly. So the energy meter is running with an external
trigger. I am communicating with the device via StreamDevice using
serial commands.
The device supports two acquisition modes: Polling ("Free running") and
I/O interrupt (device is generating interrupts).
The problem is, once I get into I/O Interrupt mode @ 10 Hz, the device
is so busy receiving the data, that any other byte streams send to it
via StreamDevice do not get through. The consequences are that I am not
able to send the command to end the I/O Interrupt mode once I started it
and get back to Polling ("free running"), and also that the devices does
not receive its other statuses.
At really low repetition rates (@ 0.5 Hz) this problem does not occur,
the device has "time to answer".
Did anybody deal with a similar problem? Is it possible to solve without
writing a driver?
Best regards
Marek Böhm
- RE: Gentec S-link power meter problem with ending I/O interrupt measurement Mazanec Tomáš
Problems using static database routines to modify IOCs marc . lormand
Re: StreamDevice reading waveforms Anthony Pietryla
<2015>
RE: Problems using static database routines to modify IOCs freddie.akeroyd
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
