Hi Matt,
Thanks for this - this seems to solve the problem properly and I didn't notice any negative performance issues in what we are doing with it.
Ian
Sent: 13 April 2015 08:50
To: Bush, Ian (Tessella,RAL,CLF); [email protected]
Subject: RE: CSS Boy and Signed/Unsigned Int Issue
Hi Ian,
At Diamond we wanted this functionality so we made a patch which converts the data (on the UI thread) for the intensity graph. As this may negatively affect the performance, and doesn't use the new Java 8 unsigned type for the conversion, it isn't merged into CSS. You can see the discussion and pull request here:
https://github.com/ControlSystemStudio/cs-studio/issues/823
Matt
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: 08 April 2015 12:01
To: [email protected]
Subject: CSS Boy and Signed/Unsigned Int Issue
Hi all,
I am having a problem with a camera that uses unsigned 8-bit integers for its values, which get interpreted as -127 --> 128 instead of 0 --> 255 in CSS BOY.
I saw on a previous discussion there was a suggested workaround (http://www.aps.anl.gov/epics/tech-talk/2014/msg00510.php), but this does not work for me due to some auto-normalisation scripts we are using, and this would also prevent choosing color maps.
I was just wondering if anyone had found a better solution to the issue? Trying to use a Python script to correct the values seems to be extremely slow.
Ian
- CSS Boy and Signed/Unsigned Int Issue ian.bush
- RE: CSS Boy and Signed/Unsigned Int Issue matthew.furseman
Re: StreamDevice reading waveforms Dirk Zimoch
Re: StreamDevice reading waveforms Anthony Pietryla
<2015>
Analog output record (softChannel): How to easily prevent VAL field's clipping within limits Heinz Junkes
<2015>
