The database records and the protocol file are listed below. When I process the record only the first values (first row of data) are written to each record. With asyn debugging turned on the console shows all three sets of data:
The protocol file has:
getTBT_XY {
Separator = "\n";
out "TBT_XY 3";
in " %(\$1TBT_Horizontal)d %(\$1TBT_Vertical)d";
ExtraInput = Ignore;
The database records are:
record(waveform, "$(P)$(R)TBT_Horizontal")
field(DESC, "TBT Horizontal")
field(DTYP, "stream")
field(INP, "@spark.proto getTBT_XY($(P)$(R)) $(PORT)")
field(NELM, "262144")
field(EGU, "um")
field(FTVL, "LONG")
record(waveform, "$(P)$(R)TBT_Vertical")
field(DESC, "TBT Vertical")
field(DTYP, "Soft Channel")
field(EGU, "um")
field(FTVL, "LONG")
When I comment out the “ExtraInput = Ignore;” line in the protocol file I get error messages:
2015/04/09 15:53:58.170 L0 wrote
TBT_XY 3
2015/04/09 15:53:58.170 L0 asynOctetBase interrupt
2015/04/09 15:53:58.171 L0 read
3333 -1111
-3333 -5556
-2000 0
2015/04/09 15:53:58.271 L0 B:Spark:TBT_Horizontal: 29 bytes surplus input "<0a> -3333 -5556<0a> -200..."
2015/04/09 15:53:58.271 L0 B:Spark:TBT_Horizontal: after 13 bytes: " 3333 -1111"
caget -# 5 B:Spark:TBT_Horizontal
B:Spark:TBT_Horizontal 5 3333 0 0 0 0
caget -# 5 B:Spark:TBT_Vertical
B:Spark:TBT_Vertical 5 -1111 -3333 0 0 0
Anthony Pietryla
Principal Controls Engineer
Advanced Photon Source
Argonne National Laboratory
Phone: 630-252-7430
Fax: 630-252-6123
