1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Stream device problem with redirection in @mismatch
To: Mazanec Tomáš <[email protected]>, Tech Talk <[email protected]>
Date: Tue, 07 Apr 2015 15:32:41 +0200
Hi Tomas,
please find attached shell output with ioc start up and
buffer overflow. Thanks for the hint I already used it.
I agree it is very handy (in my code commented now).
   Jan
#!../../bin/linux-x86_64/diode
## You may have to change diode to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocdiode")
epicsEnvSet("TOP","/home/davidmichel/HiLASE/experimental/cw")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
epicsEnvSet("STREAMDEVICE","/usr/local/epics/support/stream/current")
epicsEnvSet("ASYN","/usr/local/epics/support/asyn/current")
epicsEnvSet("AUTOSAVE","/usr/local/epics/support/autosave/current")
cd /home/davidmichel/HiLASE/experimental/cw
dbLoadDatabase "dbd/diode.dbd"
diode_registerRecordDeviceDriver pdbbase
## Autosave setup
set_savefile_path("/home/davidmichel/HiLASE/experimental/cw/autoSaveRestore")
set_requestfile_path("/home/davidmichel/HiLASE/experimental/cw/autoSaveRestore")
set_pass0_restoreFile("diode.sav")
## Asyn/stream setup
epicsEnvSet("STREAM_PROTOCOL_PATH","/home/davidmichel/HiLASE/experimental/cw/protocols")
#drvAsynSerialPortConfigure("fibotec1","/dev/ttyS1")
drvAsynSerialPortConfigure("fibotec1","/dev/ttyS1",0,0,0)
asynSetOption("fibotec1",0,"baud","115200")
asynSetOption("fibotec1",0,"bits","8")
asynSetOption("fibotec1",0,"parity","none")
asynSetOption("fibotec1",0,"stop","1")
asynSetOption("fibotec1",0,"clocal","Y")
asynSetOption("fibotec1",0,"crtscts","N")
#asynOctetSetInputEos("fibotec1", -1, "\r")
#asynOctetSetOutputEos("fibotec1", -1, "\r")
#asynSetTraceMask("fibotec1",-1,0x9)
#asynSetTraceIOMask("fibotec1",-1,0x2)
epicsEnvSet("DEVICE", "TEST_CO-CWS")
## Load record instances
dbLoadRecords("db/fibotecLtbis.db", "device=TEST_CO-CWS, port=fibotec1")
dbLoadRecords("db/fibotecLtbisChannel.db", "device=TEST_CO-CWS:CH1, port=fibotec1, channel=1") dbLoadRecords("db/fibotecLtbisChannel.db", "device=TEST_CO-CWS:CH2, port=fibotec1, channel=2") dbLoadRecords("db/fibotecLtbisChannel.db", "device=TEST_CO-CWS:CH3, port=fibotec1, channel=3") dbLoadRecords("db/fibotecLtbisChannel.db", "device=TEST_CO-CWS:CH4, port=fibotec1, channel=4")
cd /home/davidmichel/HiLASE/experimental/cw/iocBoot/iocdiode
iocInit
Starting iocInit
## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$
## EPICS Base built Aug  8 2013
reboot_restore: entry for file 'diode.sav'
reboot_restore (v5.1): entry for file 'diode.sav'
reboot_restore: Found filename 'diode.sav' in restoreFileList.
*** restoring from '/home/davidmichel/HiLASE/experimental/cw/autoSaveRestore/diode.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'diode.sav'
*** buffer overflow detected ***: ../../bin/linux-x86_64/diode terminated
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x37)[0x7f9c3c0fe387]
/lib/x86_64-linux-gnu/libc.so.6(+0x109280)[0x7f9c3c0fd280]
/lib/x86_64-linux-gnu/libc.so.6(+0x1086e9)[0x7f9c3c0fc6e9]
/lib/x86_64-linux-gnu/libc.so.6(_IO_default_xsputn+0xdd)[0x7f9c3c06f3bd]
/lib/x86_64-linux-gnu/libc.so.6(_IO_vfprintf+0x25c2)[0x7f9c3c03ec32]
/lib/x86_64-linux-gnu/libc.so.6(__vsprintf_chk+0x94)[0x7f9c3c0fc784]
/lib/x86_64-linux-gnu/libc.so.6(__sprintf_chk+0x7d)[0x7f9c3c0fc6cd]
/usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so(_ZN6Stream15getFieldAddressEPKcR12StreamBuffer+0xcd)[0x7f9c3d4bd34d]
/usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so(_ZN20StreamProtocolParser8Protocol13compileFormatER12StreamBufferRPKc10FormatTypePNS_6ClientE+0x40b)[0x7f9c3d4b362b]
/usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so(_ZN20StreamProtocolParser8Protocol13compileStringER12StreamBufferRPKc10FormatTypePNS_6ClientEi+0x3ac)[0x7f9c3d4b3d4c]
/usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so(_ZN10StreamCore14compileCommandEPN20StreamProtocolParser8ProtocolER12StreamBufferPKcRS6_+0x16a)[0x7f9c3d4b6d4a]
/usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so(_ZN20StreamProtocolParser8Protocol15compileCommandsER12StreamBufferRPKcPNS_6ClientE+0x73)[0x7f9c3d4b4c63]
/usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so(_ZN20StreamProtocolParser8Protocol11getCommandsEPKcR12StreamBufferPNS_6ClientE+0xab)[0x7f9c3d4b4dfb]
/usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so(_ZN10StreamCore7compileEPN20StreamProtocolParser8ProtocolE+0x35c)[0x7f9c3d4b7f1c]
/usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so(_ZN10StreamCore5parseEPKcS1_+0x137)[0x7f9c3d4b8077]
/usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so(_ZN6Stream10initRecordEPKcS1_S1_iS1_+0x9e)[0x7f9c3d4bf57e]
/usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so(streamInitRecord+0xde)[0x7f9c3d4bf93e]
/usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so(+0x1bd2e)[0x7f9c3d4abd2e]
/usr/local/epics/base-3.14.12.3/lib/linux-x86_64/librecIoc.so.3.14(+0xa569)[0x7f9c3d052569]
/usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libmiscIoc.so.3.14(iocBuild+0x42f)[0x7f9c3cc3e91f]
/usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libmiscIoc.so.3.14(iocInit+0x9)[0x7f9c3cc3ec69]
/usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libCom.so.3.14(+0x2b578)[0x7f9c3c3de578]
../../bin/linux-x86_64/diode[0x404e82]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed)[0x7f9c3c01576d]
../../bin/linux-x86_64/diode[0x404ecd]
======= Memory map: ========
00400000-00407000 r-xp 00000000 08:03 142048 /home/davidmichel/HiLASE/experimental/cw/bin/linux-x86_64/diode 00606000-00607000 r--p 00006000 08:03 142048 /home/davidmichel/HiLASE/experimental/cw/bin/linux-x86_64/diode 00607000-00608000 rw-p 00007000 08:03 142048 /home/davidmichel/HiLASE/experimental/cw/bin/linux-x86_64/diode
00608000-00609000 rw-p 00000000 00:00 0
01577000-0167f000 rw-p 00000000 00:00 0 [heap]
7f9c1c000000-7f9c1c021000 rw-p 00000000 00:00 0
7f9c1c021000-7f9c20000000 ---p 00000000 00:00 0
7f9c24000000-7f9c24021000 rw-p 00000000 00:00 0
7f9c24021000-7f9c28000000 ---p 00000000 00:00 0
7f9c28000000-7f9c28021000 rw-p 00000000 00:00 0
7f9c28021000-7f9c2c000000 ---p 00000000 00:00 0
7f9c2c000000-7f9c2c021000 rw-p 00000000 00:00 0
7f9c2c021000-7f9c30000000 ---p 00000000 00:00 0
7f9c30000000-7f9c30021000 rw-p 00000000 00:00 0
7f9c30021000-7f9c34000000 ---p 00000000 00:00 0
7f9c34000000-7f9c34021000 rw-p 00000000 00:00 0
7f9c34021000-7f9c38000000 ---p 00000000 00:00 0
7f9c3980a000-7f9c3980b000 ---p 00000000 00:00 0
7f9c3980b000-7f9c3990b000 rw-p 00000000 00:00 0 [stack:2513]
7f9c3990b000-7f9c3990c000 ---p 00000000 00:00 0
7f9c3990c000-7f9c39b0c000 rw-p 00000000 00:00 0 [stack:2512]
7f9c39b0c000-7f9c39b0d000 ---p 00000000 00:00 0
7f9c39b0d000-7f9c39d0d000 rw-p 00000000 00:00 0 [stack:2511]
7f9c39d0d000-7f9c39d0e000 ---p 00000000 00:00 0
7f9c39d0e000-7f9c39f0e000 rw-p 00000000 00:00 0 [stack:2510]
7f9c39f0e000-7f9c39f0f000 ---p 00000000 00:00 0
7f9c39f0f000-7f9c3a10f000 rw-p 00000000 00:00 0 [stack:2509]
7f9c3a10f000-7f9c3a110000 ---p 00000000 00:00 0
7f9c3a110000-7f9c3a210000 rw-p 00000000 00:00 0 [stack:2508]
7f9c3a210000-7f9c3a211000 ---p 00000000 00:00 0
7f9c3a211000-7f9c3a291000 rw-p 00000000 00:00 0 [stack:2507]
7f9c3a291000-7f9c3a292000 ---p 00000000 00:00 0
7f9c3a292000-7f9c3a392000 rw-p 00000000 00:00 0 [stack:2506]
7f9c3a392000-7f9c3a393000 ---p 00000000 00:00 0
7f9c3a393000-7f9c3a493000 rw-p 00000000 00:00 0 [stack:2505] 7f9c3a493000-7f9c3a4b5000 r-xp 00000000 08:03 1969840 /lib/x86_64-linux-gnu/libtinfo.so.5.9 7f9c3a4b5000-7f9c3a6b5000 ---p 00022000 08:03 1969840 /lib/x86_64-linux-gnu/libtinfo.so.5.9 7f9c3a6b5000-7f9c3a6b9000 r--p 00022000 08:03 1969840 /lib/x86_64-linux-gnu/libtinfo.so.5.9 7f9c3a6b9000-7f9c3a6ba000 rw-p 00026000 08:03 1969840 /lib/x86_64-linux-gnu/libtinfo.so.5.9 7f9c3a6ba000-7f9c3a6bc000 r-xp 00000000 08:03 1990009 /lib/x86_64-linux-gnu/libdl-2.15.so 7f9c3a6bc000-7f9c3a8bc000 ---p 00002000 08:03 1990009 /lib/x86_64-linux-gnu/libdl-2.15.so 7f9c3a8bc000-7f9c3a8bd000 r--p 00002000 08:03 1990009 /lib/x86_64-linux-gnu/libdl-2.15.so 7f9c3a8bd000-7f9c3a8be000 rw-p 00003000 08:03 1990009 /lib/x86_64-linux-gnu/libdl-2.15.so 7f9c3a8be000-7f9c3a8c5000 r-xp 00000000 08:03 1989992 /lib/x86_64-linux-gnu/librt-2.15.so 7f9c3a8c5000-7f9c3aac4000 ---p 00007000 08:03 1989992 /lib/x86_64-linux-gnu/librt-2.15.so 7f9c3aac4000-7f9c3aac5000 r--p 00006000 08:03 1989992 /lib/x86_64-linux-gnu/librt-2.15.so 7f9c3aac5000-7f9c3aac6000 rw-p 00007000 08:03 1989992 /lib/x86_64-linux-gnu/librt-2.15.so 7f9c3aac6000-7f9c3aaff000 r-xp 00000000 08:03 1969826 /lib/x86_64-linux-gnu/libreadline.so.6.2 7f9c3aaff000-7f9c3acff000 ---p 00039000 08:03 1969826 /lib/x86_64-linux-gnu/libreadline.so.6.2 7f9c3acff000-7f9c3ad01000 r--p 00039000 08:03 1969826 /lib/x86_64-linux-gnu/libreadline.so.6.2 7f9c3ad01000-7f9c3ad07000 rw-p 0003b000 08:03 1969826 /lib/x86_64-linux-gnu/libreadline.so.6.2
7f9c3ad07000-7f9c3ad08000 rw-p 00000000 00:00 0
7f9c3ad08000-7f9c3ad0c000 r-xp 00000000 08:03 2371472 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libdbtoolsIoc.so.3.14 7f9c3ad0c000-7f9c3af0b000 ---p 00004000 08:03 2371472 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libdbtoolsIoc.so.3.14 7f9c3af0b000-7f9c3af0c000 r--p 00003000 08:03 2371472 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libdbtoolsIoc.so.3.14 7f9c3af0c000-7f9c3af0d000 rw-p 00004000 08:03 2371472 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libdbtoolsIoc.so.3.14
7f9c3af0d000-7f9c3af0e000 rw-p 00000000 00:00 0
7f9c3af0e000-7f9c3af1e000 r-xp 00000000 08:03 2371475 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/librsrvIoc.so.3.14 7f9c3af1e000-7f9c3b11d000 ---p 00010000 08:03 2371475 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/librsrvIoc.so.3.14 7f9c3b11d000-7f9c3b11e000 r--p 0000f000 08:03 2371475 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/librsrvIoc.so.3.14 7f9c3b11e000-7f9c3b11f000 rw-p 00010000 08:03 2371475 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/librsrvIoc.so.3.14 7f9c3b11f000-7f9c3b17f000 r-xp 00000000 08:03 2371451 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libca.so.3.14 7f9c3b17f000-7f9c3b37e000 ---p 00060000 08:03 2371451 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libca.so.3.14 7f9c3b37e000-7f9c3b382000 r--p 0005f000 08:03 2371451 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libca.so.3.14 7f9c3b382000-7f9c3b384000 rw-p 00063000 08:03 2371451 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libca.so.3.14 7f9c3b384000-7f9c3b399000 r-xp 00000000 08:03 1969764 /lib/x86_64-linux-gnu/libgcc_s.so.1 7f9c3b399000-7f9c3b598000 ---p 00015000 08:03 1969764 /lib/x86_64-linux-gnu/libgcc_s.so.1 7f9c3b598000-7f9c3b599000 r--p 00014000 08:03 1969764 /lib/x86_64-linux-gnu/libgcc_s.so.1 7f9c3b599000-7f9c3b59a000 rw-p 00015000 08:03 1969764 /lib/x86_64-linux-gnu/libgcc_s.so.1 7f9c3b59a000-7f9c3b695000 r-xp 00000000 08:03 1990008 /lib/x86_64-linux-gnu/libm-2.15.so 7f9c3b695000-7f9c3b894000 ---p 000fb000 08:03 1990008 /lib/x86_64-linux-gnu/libm-2.15.so 7f9c3b894000-7f9c3b895000 r--p 000fa000 08:03 1990008 /lib/x86_64-linux-gnu/libm-2.15.so 7f9c3b895000-7f9c3b896000 rw-p 000fb000 08:03 1990008 /lib/x86_64-linux-gnu/libm-2.15.so 7f9c3b896000-7f9c3b978000 r-xp 00000000 08:03 925456 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.16 7f9c3b978000-7f9c3bb77000 ---p 000e2000 08:03 925456 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.16 7f9c3bb77000-7f9c3bb7f000 r--p 000e1000 08:03 925456 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.16 7f9c3bb7f000-7f9c3bb81000 rw-p 000e9000 08:03 925456 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.16
7f9c3bb81000-7f9c3bb96000 rw-p 00000000 00:00 0
7f9c3bb96000-7f9c3bbae000 r-xp 00000000 08:03 1989999 /lib/x86_64-linux-gnu/libpthread-2.15.so 7f9c3bbae000-7f9c3bdad000 ---p 00018000 08:03 1989999 /lib/x86_64-linux-gnu/libpthread-2.15.so 7f9c3bdad000-7f9c3bdae000 r--p 00017000 08:03 1989999 /lib/x86_64-linux-gnu/libpthread-2.15.so 7f9c3bdae000-7f9c3bdaf000 rw-p 00018000 08:03 1989999 /lib/x86_64-linux-gnu/libpthread-2.15.so
7f9c3bdaf000-7f9c3bdb3000 rw-p 00000000 00:00 0
7f9c3bdb3000-7f9c3bdef000 r-xp 00000000 08:03 2371463 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libdbIoc.so.3.14 7f9c3bdef000-7f9c3bfee000 ---p 0003c000 08:03 2371463 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libdbIoc.so.3.14 7f9c3bfee000-7f9c3bff0000 r--p 0003b000 08:03 2371463 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libdbIoc.so.3.14 7f9c3bff0000-7f9c3bff2000 rw-p 0003d000 08:03 2371463 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libdbIoc.so.3.14
7f9c3bff2000-7f9c3bff4000 rw-p 00000000 00:00 0
7f9c3bff4000-7f9c3c1a8000 r-xp 00000000 08:03 1989998 /lib/x86_64-linux-gnu/libc-2.15.so 7f9c3c1a8000-7f9c3c3a8000 ---p 001b4000 08:03 1989998 /lib/x86_64-linux-gnu/libc-2.15.so 7f9c3c3a8000-7f9c3c3ac000 r--p 001b4000 08:03 1989998 /lib/x86_64-linux-gnu/libc-2.15.so 7f9c3c3ac000-7f9c3c3ae000 rw-p 001b8000 08:03 1989998 /lib/x86_64-linux-gnu/libc-2.15.so
7f9c3c3ae000-7f9c3c3b3000 rw-p 00000000 00:00 0
7f9c3c3b3000-7f9c3c407000 r-xp 00000000 08:03 2371448 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libCom.so.3.14 7f9c3c407000-7f9c3c606000 ---p 00054000 08:03 2371448 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libCom.so.3.14 7f9c3c606000-7f9c3c609000 r--p 00053000 08:03 2371448 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libCom.so.3.14 7f9c3c609000-7f9c3c60b000 rw-p 00056000 08:03 2371448 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libCom.so.3.14
7f9c3c60b000-7f9c3c60c000 rw-p 00000000 00:00 0
7f9c3c60c000-7f9c3c627000 r-xp 00000000 08:03 2371456 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libdbStaticIoc.so.3.14 7f9c3c627000-7f9c3c826000 ---p 0001b000 08:03 2371456 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libdbStaticIoc.so.3.14 7f9c3c826000-7f9c3c827000 r--p 0001a000 08:03 2371456 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libdbStaticIoc.so.3.14 7f9c3c827000-7f9c3c828000 rw-p 0001b000 08:03 2371456 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libdbStaticIoc.so.3.14
7f9c3c828000-7f9c3c82a000 rw-p 00000000 00:00 0
7f9c3c82a000-7f9c3c82c000 r-xp 00000000 08:03 2371460 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libregistryIoc.so.3.14 7f9c3c82c000-7f9c3ca2b000 ---p 00002000 08:03 2371460 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libregistryIoc.so.3.14 7f9c3ca2b000-7f9c3ca2c000 r--p 00001000 08:03 2371460 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libregistryIoc.so.3.14 7f9c3ca2c000-7f9c3ca2d000 rw-p 00002000 08:03 2371460 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libregistryIoc.so.3.14 7f9c3ca2d000-7f9c3ca3a000 r-xp 00000000 08:03 2371468 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libasIoc.so.3.14 7f9c3ca3a000-7f9c3cc39000 ---p 0000d000 08:03 2371468 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libasIoc.so.3.14 7f9c3cc39000-7f9c3cc3a000 r--p 0000c000 08:03 2371468 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libasIoc.so.3.14 7f9c3cc3a000-7f9c3cc3b000 rw-p 0000d000 08:03 2371468 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libasIoc.so.3.14
7f9c3cc3b000-7f9c3cc3c000 rw-p 00000000 00:00 0
7f9c3cc3c000-7f9c3cc40000 r-xp 00000000 08:03 2371481 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libmiscIoc.so.3.14 7f9c3cc40000-7f9c3ce3f000 ---p 00004000 08:03 2371481 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libmiscIoc.so.3.14 7f9c3ce3f000-7f9c3ce40000 r--p 00003000 08:03 2371481 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libmiscIoc.so.3.14 7f9c3ce40000-7f9c3ce41000 rw-p 00004000 08:03 2371481 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libmiscIoc.so.3.14 7f9c3ce41000-7f9c3ce47000 r-xp 00000000 08:03 2371484 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libsoftDevIoc.so.3.14 7f9c3ce47000-7f9c3d046000 ---p 00006000 08:03 2371484 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libsoftDevIoc.so.3.14 7f9c3d046000-7f9c3d047000 r--p 00005000 08:03 2371484 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libsoftDevIoc.so.3.14 7f9c3d047000-7f9c3d048000 rw-p 00006000 08:03 2371484 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/libsoftDevIoc.so.3.14 7f9c3d048000-7f9c3d06e000 r-xp 00000000 08:03 2371478 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/librecIoc.so.3.14 7f9c3d06e000-7f9c3d26e000 ---p 00026000 08:03 2371478 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/librecIoc.so.3.14 7f9c3d26e000-7f9c3d26f000 r--p 00026000 08:03 2371478 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/librecIoc.so.3.14 7f9c3d26f000-7f9c3d271000 rw-p 00027000 08:03 2371478 /usr/local/epics/base-3.14.12.3/lib/linux-x86_64/librecIoc.so.3.14 7f9c3d271000-7f9c3d28d000 r-xp 00000000 08:03 3539297 /usr/local/epics/support/autosave/autosave-5-1/lib/linux-x86_64/libautosave.so 7f9c3d28d000-7f9c3d48d000 ---p 0001c000 08:03 3539297 /usr/local/epics/support/autosave/autosave-5-1/lib/linux-x86_64/libautosave.so 7f9c3d48d000-7f9c3d48e000 r--p 0001c000 08:03 3539297 /usr/local/epics/support/autosave/autosave-5-1/lib/linux-x86_64/libautosave.so 7f9c3d48e000-7f9c3d48f000 rw-p 0001d000 08:03 3539297 /usr/local/epics/support/autosave/autosave-5-1/lib/linux-x86_64/libautosave.so
7f9c3d48f000-7f9c3d490000 rw-p 00000000 00:00 0
7f9c3d490000-7f9c3d4ce000 r-xp 00000000 08:03 932133 /usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so 7f9c3d4ce000-7f9c3d6ce000 ---p 0003e000 08:03 932133 /usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so 7f9c3d6ce000-7f9c3d6d0000 r--p 0003e000 08:03 932133 /usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so 7f9c3d6d0000-7f9c3d6d2000 rw-p 00040000 08:03 932133 /usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so 7f9c3d6d2000-7f9c3d73e000 r-xp 00000000 08:03 3674172 /usr/local/epics/support/asyn/r2251/lib/linux-x86_64/libasyn.so 7f9c3d73e000-7f9c3d93d000 ---p 0006c000 08:03 3674172 /usr/local/epics/support/asyn/r2251/lib/linux-x86_64/libasyn.so 7f9c3d93d000-7f9c3d93f000 r--p 0006b000 08:03 3674172 /usr/local/epics/support/asyn/r2251/lib/linux-x86_64/libasyn.so 7f9c3d93f000-7f9c3d942000 rw-p 0006d000 08:03 3674172 /usr/local/epics/support/asyn/r2251/lib/linux-x86_64/libasyn.so 7f9c3d942000-7f9c3d964000 r-xp 00000000 08:03 1990007 /lib/x86_64-linux-gnu/ld-2.15.so
7f9c3d9bc000-7f9c3d9bd000 ---p 00000000 00:00 0
7f9c3d9bd000-7f9c3dabd000 rw-p 00000000 00:00 0 [stack:2504]
7f9c3dabd000-7f9c3dabe000 ---p 00000000 00:00 0
7f9c3dabe000-7f9c3db49000 rw-p 00000000 00:00 0 [stack:2503]
7f9c3db5c000-7f9c3db64000 rw-p 00000000 00:00 0
7f9c3db64000-7f9c3db65000 r--p 00022000 08:03 1990007 /lib/x86_64-linux-gnu/ld-2.15.so 7f9c3db65000-7f9c3db67000 rw-p 00023000 08:03 1990007 /lib/x86_64-linux-gnu/ld-2.15.so 7fffa2512000-7fffa2533000 rw-p 00000000 00:00 0 [stack] 7fffa25d4000-7fffa25d6000 r-xp 00000000 00:00 0 [vdso] ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
Aborted (core dumped)
On 2015-04-02 00:22, Mazanec Tomáš wrote:
Hi Jan
Could you provide ioc shell output with ioc start up and the error messages?
It is usually very handy if asyn trace output is included. To do so, put these :
asynSetTraceIOMask("$(PORT)",0,4)
asynSetTraceMask("$(PORT)",0,9)
into you startup script before iocInit().
Tomas
Od: [email protected] [[email protected]] za
uživatele Růžička Jan
Odesláno: 1. dubna 2015 15:51
Komu: [email protected]
Předmět: Stream device problem with redirection in @mismatch
Hi all,
I have a device that sends a response on command
"on/off" (requested value) or "INTERLOCK").
I use a @mismatch exception handler and redirection to record in
order to catch this "INTERLOCK" string. After that I turn on or off the
LED widget
(Interlocked or Non-Interlocked). When I started IOC it gave me a buffer
overflow.
Buffer overflow is appeared after adding arg: (\$2).
DB and proto file are following:
DB:
# requested value laser state
record(bi, "$(device):StatEnable")
     field(DESC, "Laser Enabled")
     field(DTYP, "stream")
     field(INP,  "@fibotecLtbis.proto
get_enable($(channel),$(device):StatEnableInterlock) $(port)")
     field(SCAN, "1 second")
     field(ZNAM, "Off")
     field(ONAM, "On")
     field(PINI,"YES")
#makro
#channel=1
#device=name:ch1
#Catching INTERLOCK message
record(bi, "$(device):StatEnableInterlock")
     field(ZNAM, "INTERLOCK")
     field(ONAM, "Ok")
     field(VAL, "1")
     field(PINI,"YES")
Proto file:
get_enable  { out "get ch\$1 status"; in "get ch\$1 status\r\r\n =
%{off|on } ";
@mismatch {in "get ch\$1 status\r\r\n%(\$2){INTERLOCK}";}}
Thanks Jan
Stream device problem with redirection in @mismatch ruzickaj
RE: Stream device problem with redirection in @mismatch Mazanec Tomáš
Prev: Program Available for the Spring 2015 EPICS Collaboration Meeting Spring 2015 EPICS Collaboration Meeting
Next: aravisGigEApp and glib Specht, Eliot D.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Stream device problem with redirection in @mismatch Mazanec Tomáš
Next: Re: Stream device problem with redirection in @mismatch Dirk Zimoch
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
