1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: MTCA.4 board with IO modules
Date: Tue, 7 Apr 2015 11:31:35 +0000
Hi Emmanuel,
Our boards are not MTCA. They are pizza boxes. (More appropriate for the NY area).
They have two components:
    The Digital Front End which has
          Xilinz 6
          Event Receiver
          Optical Redundant IO Network for low latency data comm
          4 Ethernet SFPs
          4 GB of DDR RAM
   IO Connector
          Ethernet connection for EPICS
Applications:
       BPM: DFE and a BPM Analog Front End
       Cell Controller: used to distribute BPMs and perform FOFB at 10 Hz, Sends control points over Ethernet to PSs.
       Active Interlock: Cell controller that performs machine protection using 10 kHz machine data
       Correlator: detects events at (50? MHz) - no extra IO used
       Triggered Position Capture: AFE is a general IO board with 8 encoder mirroring signals
       Gerneral Beam line IO: AFE has a set of analog and digital signals that can be captured and time stamped for experiments 8 nsec resolution
LBL is using this platform for their BPMs. THey have a significantly different AFE and they have rewritten the DFE code. The use AXI(SP?), instead of the PLB bus. They plan to make this open source.
BNL has submitted all of the paperwork to make our boards open source.
BNL has ported over the EVR and Synchronous Data Interchange to the ZYNC FPGA. The new DFE is not yet completed.
Bob
Prev: RE: problem scale word data Mark Rivers
Next: Re: epics for Aerotech A3200 Kurt Goetze
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: MTCA.4 board with IO modules Emmanuel Mayssat
Next: Re: MTCA.4 board with IO modules Konrad, Martin
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
