1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Stream device: how to send waveform of chars without null terminator?
To: Isabella Rey <[email protected]>
Date: Thu, 2 Apr 2015 16:17:35 +0200
Hmm... I added printStatus in 2.6.4.
Don't mind. It is just some debugging stuff.
Maybe I should update the version on the web. :-)
Dirk
On 02.04.2015 16:08, Isabella Rey wrote:
Hi Dirk,
Thanks for the file.
I have replaced it in the StreamDevice src directory, but when I ran
make it gave me this error:
../StreamEpics.cc: In static member function ‘static long int
Stream::report(int)’:
../StreamEpics.cc:356:26: error: ‘class Stream’ has no member named
‘printStatus’
make[2]: *** [StreamEpics.o] Error 1
I tried commenting out the line 356, and got no error - Should I just
remove the line, or do I need to update StreamCore? I am running on
StreamDevice 2.6
Apart from that, with the line 356 commented out, I've changed the
protocol to use %s and I don't get the null character anymore.  :)
Cheers,
Isabella
On 2 April 2015 at 14:03, Dirk Zimoch <[email protected]
<mailto:[email protected]>> wrote:
    Here is the bug fix.
    Dirk
    On 01.04.2015 14:03, Dirk Zimoch wrote:
        On 01.04.2015 12:07, Isabella Rey wrote:
            Hi Ralph,
            Yes, but with %s the device receives something like:
            load_curve 675892112117108115101461161201__160 3870\r\n
        You are right. And I think that is a bug.
        Dirk
            The null character corresponds to the 0 at the end of the
            waveform (I've
            checked it with small strings)
            Isabella
            On 1 April 2015 at 10:44, Ralph Lange <[email protected]
            <mailto:[email protected] <mailto:[email protected]>>> wrote:
                 Have you tried using "%s" for the string output?
                 ~Ralph
                 On 01/04/2015 10:44, Isabella Rey wrote:
                     Hi All,
                     I have a device to which I need to send a file path
            followed by
                     a number:
                     example:
                     load_curve C:\pulse.txt 3870
                     The file path is stored in the database as a
            waveform of chars.
                     When I run the protocol stream device sends (what I
            think is) a
                     null terminator after the file path:
                     device receives:
                     load_curve C:\pulse.txt\x00 3870
                     Is there any way of getting rid of the \x00 terminator?
                     Below I copy my protocol and the database records.
                     Cheers,
                     Isabella
                     I've defined the protocol in stream device as:
                     load_curve
                          out "load_curve %(\$1)c %(\$2)i";
                          in "%(\$1:\$2)b";
                     and in the database I have:
                     record(bo, "DEV:LOAD_CURVE") {
                        field(DTYP, "stream")
                        field(OUT, "@my.proto load_curve(DEV:CURVE_FILE,
            DEV:VPI)
                     $(PORT)")
                     record(waveform, "DEV:CURVE_FILE") {
                        field(DESC, "File path")
                        field(DTYP, "Soft Channel")
                        field(NELM, "256")
                        field(FTVL, "CHAR")
Stream device: how to send waveform of chars without null terminator? Isabella Rey
Re: Stream device: how to send waveform of chars without null terminator? Ralph Lange
Re: Stream device: how to send waveform of chars without null terminator? Isabella Rey
Re: Stream device: how to send waveform of chars without null terminator? Dirk Zimoch
Prev: Re: Stream device problem with redirection in @mismatch Dirk Zimoch
Next: Device support for agilent 34410A multimeter? Lionberger, Carl A.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Stream device: how to send waveform of chars without null terminator? Isabella Rey
Next: Re: seq-2.2.1 assertion failure Benjamin Franksen
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
