1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: seq-2.2.1 assertion failure
To: "William F. Steele" <[email protected]>
Cc: [email protected]
Date: Wed, 1 Apr 2015 13:19:28 +0200
Hi William
Thanks for the bug report.
After pondering the code for a while I have come to the conclusion that
the assertion is indeed wrong. The assumption was that the dbr field of
the event_handler_args struct that is passed to an event handler can
only be NULL if the request was a put request. Apparently this is wrong:
when connection to a PV is lost while a get request is pending, the
handler will be called with a NULL dbr field, too.
I will make a patch that removes the assertion.
Cheers
Ben
On Tuesday 31 March 2015 17:55:18 William F. Steele wrote:
> Hello Benjamin,
> Following the instructions, I’m sending this error message to you
> which popped up while starting the undulator control system here at
> Lawrence Berkeley Lab’s Advanced Light Source:
> CA.Client.Exception...............................................
>     Warning: "Virtual circuit unresponsive"
>     Context: "ffbsec04.als.lbl.gov:5064"
>     Source File: ../tcpiiu.cpp line 945
>     Current Time: Tue Mar 31 2015 15:56:01.345016461
> A call to 'assert((value==NULL)==(evtype == pvEventPut))'
>     by thread 'timerQueue' failed in ../seq_ca.c line 282.
> EPICS Release EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$.
> Local time is 2015-03-31 15:56:01.349364576 PDT
> Please E-mail this message to [email protected] or
> to [email protected] Calling epicsThreadSuspendSelf()
> 31Mar 15:56:41 FF04-2 Resetting: Errors during reset: 5 total
> Unexpected problem with CA circuit to server
> "ffbsec04.als.lbl.gov:5064" was "Connection reset by peer" -
> disconnecting 31Mar 15:56:51 FF04-2 Resetting: Connect count !=
> Channel count Connect count = 104, Channel count = 105
> Up ’til now I had been using seq-2.1.16. I just switched to seq-2.2.1.
> I am running 8 soft IOCs (on 2 PowerPMAC controllers running Linux,
> EPICS 3.14.12.4) each running an instance of the same sequencer
> program. I saw this assertion on only one of the sequencer instances.
> It occurred when a computer, to which the sequencer had a CA
> connection, was rebooted (all of the computers to which all of the
> sequencers had connections were rebooted during our startup
> procedure). The soft IOC was not able to recover on its own, but
> restarting the did clear the problem.
> Thanks,
> William Steele
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Prev: Re: Stream device: how to send waveform of chars without null terminator? Isabella Rey
Next: Re: Stream device: how to send waveform of chars without null terminator? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Stream device: how to send waveform of chars without null terminator? Dirk Zimoch
Next: STAT=SCAN recover Isabella Rey
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
