1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: related to controls in edm
To: [email protected]
Date: Fri, 27 Mar 2015 08:26:13 -0700
Priya:
We often do this kind of thing using a scripting language such as Perl. The EDM button is a 'Shell Command' widget, and it launches the Perl script to perform the sequencing. The Perl script uses the EPICS Channel Access module to read and write the accordant EPICS PVs for performing the sequencing. Naturally, the script runs on the host that is running EDM.
While it seems desirable to implement everything using EPICS record logic that runs on the IOC, it is invariably too complex to implement that way. Other labs often use the SNL facility for such purposes, and that is potentially a better method. Hopefully others will contribute ideas about how to implement that.
Rod Nussbaumer
TRIUMF,
Vancouver, Canada
On 03/27/2015 05:39 AM, Mooney, Tim M. wrote:
Hi Priya,
I would do this with a sscan record. See
http://www.aps.anl.gov/bcda/synApps/sscan/sscanDoc.html
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
behalf of priya tiwari [[email protected]]
*Sent:* Friday, March 27, 2015 1:26 AM
*To:* [email protected]
*Subject:* related to controls in edm
Hello sir,
I am beginner in EDM and I want to add a button in EDM. When I will
press the button then my progam should be start otherwise should not be
start. In case of my program, I am going from 10 mA(i.e. initial value
in current source) to 120 mA(i.e. final value) with step of 10.How to
use message button which act as a START button of my program and this
should be press(toggle) only one time and program should be proceed and
also I want to add stop button so that when press stop then whole
program should be stop.How to perform this task ,I have no idea because
for loop or while loop does not work in VDCT directly. Please provide
example for this type of task.
Thanks in advance......
related to controls in edm priya tiwari
RE: related to controls in edm Mooney, Tim M.
Prev: Recent encrypted mails to tech-talk Ralph Lange
Next: Entry-level software job posting Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: related to controls in edm Mooney, Tim M.
Next: FLNK + Alarm Fields Bernardo Carvalho
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
