1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: pyepics not updating pv.enum_strs after connection
To: [email protected]
Date: Wed, 25 Mar 2015 21:08:11 -0400
On 03/25/2015 02:25 PM, Matt Newville wrote:
> Is it reasonable to simply change the event subscription mask to include
> DBE_PROPERTY by default?  Will doing so work (in the sense of "not
> fail"), even though only getting VALUE, LOG, and ALARM events) for older
> iocs and through gateways?  If so, that's an easy change to make.
CA gateway does (or at least did) fail monitor subscripts with bits
other than VALUE, LOG, and ALARM set.
http://www.aps.anl.gov/epics/tech-talk/2012/msg02352.php
A separate subscription for DBE_PROPERTY is probably better in any event
as you'll want to subscript to DBR_CTRL_* for DBE_PROPERTY and
DBR_TIME_* for DBE_VALUE, etc.
pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
Re: pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
Re: pyepics not updating pv.enum_strs after connection Matt Newville
Re: pyepics not updating pv.enum_strs after connection Dirk Zimoch
Re: pyepics not updating pv.enum_strs after connection Andrew Johnson
Prev: RE: multiple asynRecord communication conflict Mark Rivers
Next: Re: Registration Open for the Spring 2015 EPICS Collaboration Meeting Jack
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: pyepics not updating pv.enum_strs after connection Matt Newville
Next: Re: pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
