On 25.03.2015 17:21, Andrew Johnson wrote:
On 03/25/2015 10:55 AM, Dirk Zimoch wrote:
On 25.03.2015 04:46, Matt Newville wrote:
Yes, I think this idea of getting the ctrl variables in the connection
callback is a good idea, and will allow more straightforward code As it
is, a pyepics.PV is already expected to be a "rich" object, even if
sacrificing ultimate performance, and is normally expected to have the
ctrl variables. So, I think it's reasonable to have this getting of
ctrl variables as the default. I'll add that.
This is generally a good idea for every ca client. After a reboot,
anything may have changed: Enum strings, limits, units, precision, array
size, even record type (and thus data type).
Recent versions of Base (3.14.11 on) have a CA monitor event type
DBE_PROPERTY which was intended for monitoring changes to metadata like
the ctrl variables. 3.14 IOCs don't send out many property events (and
the PV Gateway doesn't support property subscriptions yet either), but
as 3.15 and later IOCs come in they make the case for using this quite a
bit more compelling. I would encourage CA client developers to read the
tech-talk threads discussing DBE_PROPERTY first though, there are a few
gotchas.
- Andrew
This is a different issue. The problem here was not that IOCs changed
their properties on the fly but after a reboot! Even EPICS 3.13 should
have been able to handle that. But many ca clients are too lazy. That
means the client programmer had not thought about the possibility that
IOCs may actually change during a reboot.
Dirk
- Re: pyepics not updating pv.enum_strs after connection Dirk Zimoch
- Re: pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
- pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
- Re: pyepics not updating pv.enum_strs after connection Matt Newville
- Re: pyepics not updating pv.enum_strs after connection Andrew Johnson
RE: multiple asynRecord communication conflict Zohar, Sioan
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
