1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: multiple asynRecord communication conflict
To: "'Zohar, Sioan'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 25 Mar 2015 15:56:16 +0000
There should be no possibility of such a conflict.  asynManager keeps a lock on the drvAsynSerialPort driver so that only one thread can talk to it at a time.
What TMOD are you using with your asyn records, Write/Read, Write, etc.?  If you need to do both a write and then a read you should use Write/Read, because that is atomic, no other thread can do a write before the read is performed.
Have you tried turning on asynTrace for the drvAsynSerialPort port?  You can then see what is happening.
Have you run asynReport on the drvAsynSerialPort port when it is no longer responding?
Are the asyn records actually still processing when the serial port is no longer communicating?
I have many IOCs with multiple asyn records talking to the same serial port and have never seen a problem.
Is this on Linux or Windows?
From: [email protected] [mailto:[email protected]] On Behalf Of Zohar, Sioan
Sent: Wednesday, March 25, 2015 10:22 AM
To: [email protected]
Subject: multiple asynRecord communication conflict
I have several asynRecord instances running in a softIOC talking to a single serial port and I suspect they are conflicting.
Everything runs fine for several hours, and then the asynRecord writes stop reaching the serial port.  (I confirmed this by sniffing the serial output using the serial port from another computer).
This error is not observed when there is only one instance of the asynRecord.
This problem does not occur on every computer, so perhaps it depends on environment settings?
I've tried daisy chaining the asynRecords by flnk'ing them.  Two asynRecords are set to scan = passive, and the other is set to scan = 1 second. I thought this would prevent the possibility of multiple asynrecord instances from talking to the port at once, but the problem persists.
Thanks in advance for your help.
Sioan
RE: multiple asynRecord communication conflict Zohar, Sioan
Prev: Re: pyepics not updating pv.enum_strs after connection Dirk Zimoch
Next: Re: pyepics not updating pv.enum_strs after connection Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: multiple asynRecord communication conflict Zohar, Sioan
Next: RE: multiple asynRecord communication conflict Zohar, Sioan
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
