1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: adding devIocStats support to motor IOCs
To: Alireza Panna <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 21 Mar 2015 04:50:50 +0000
Hi Ali,
I'll guess you haven't included the .dbd file that defines the device type  "IOC stats" to the .dbd file you are building for your IOC.  (Look for it in devIocStats-3-1-7/dbd.)  After you include the .dbd file, you may find that you also have to specify a library file from devIocStats.  You probably need something like this:
	xxx_Common_DBD += devIocStats.dbd iocAdmin.dbd
	xxx_Common_LIBS += devIocStats
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Alireza Panna [[email protected]]
Sent: Friday, March 20, 2015 10:42 PM
To: [email protected]
Subject: adding devIocStats support to motor IOCs
Hello tech-talkers,
I am having problems adding devIocStat support to asyn motor IOCS.I get the the following two errors when I run st.cmd:
when records are being loaded from iocAdminSoft.db this is the errror I keep getting:
Can't set "TEST:CA_CLNT_CNT.DTYP" to "IOC stats"
and after iocInit the following error:
Subroutine not found PV: TEST:SYSRESET recSub(init_record)
PV: TEST:CA_CLNT_CNT scanAdd: I/O Intr not valid (no get_ioint_info)
May be I am missing something.
I am using motor-6-8 and devIocStats-3-1-7 .
Any help is appreciated.
Thank you
Ali
Alireza Panna
University of Maryland, College Park
adding devIocStats support to motor IOCs Alireza Panna
Prev: adding devIocStats support to motor IOCs Alireza Panna
Next: Support for SRS SR400? Peter Mueller
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
