I start EDM with a command like this:
edm -x -ctl UI:Alert main.edl
Then the large display described by main.edl appears. When I write
'alert.edl' to UI:Alert, the smaller message described by
alert.edl pops up, floating over the large display.
But then, other activities can cause the large display to cover the
message. I try to raise the message to the top again by writing
'alert.edl' to UI:Alert again, but instead I get a new window also
displaying alert.edl, in addition to the older one (which is still
obscured under main.edl). Each write to UI:Alert creates a new
window.
I see this behavior when I write alert.edl to UI:Alert via OUT from an
scalcout record, or when I command: dbpf UI:Alert alert.edl in the
ioc shell.
When I write alert.edl to UI:Alert and the message pops up, dbgf
UI:Alert always shows an empty string (not 'alert.edl' as I
expected).
I see this behavior when UI:Alert is a stringin, or when it is a stringout.
In both cases, I define it this way, without any explicit field definitions:
record(stringin, "UI:Alert") {
Is there anything I can do so that writing to UI:Alert will raise an
existing display to the top, instead of opening another instance of
the same display?
Alternatively, is there some other way to force a display to the top, or
(better yet) create the display so it always remains on top?
Jon Jacky
- Re: EDM -ctl opens new window instead of raising old one John William Sinclair
Announcing carchivetools Michael Davidsaver
Re: pyepics not updating pv.enum_strs after connection Matt Newville
<2015>
<2015>
