1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Please help with "caput -c"
To: Benjamin Franksen <[email protected]>
Cc: "<[email protected]>" <[email protected]>
Date: Wed, 11 Mar 2015 21:27:44 +0000
Something like this might work:
record(ao, "$(P):Setpoint") {
  field(DTYP, "stream")
  field(DESC, "Setpoint temperature")
  field(OUT, "@ls336.proto setSETP($(OUT)) $(PORT) $(ADDR)")
  field(FLNK, "$(P):SetBusy")
  field(EGU, "K")
record(dfanout, "$(P):SetBusy")
   field(VAL, "1")
   field(OUTA, "$(P):Busy PP")
record(busy, "$(P):Busy")
Then some other record reading some input will set the busy back to 0 once the process is complete:
record(calcout, "$(P):CalcDone") {
  field(INPA, "$(P):Blah.VAL CP")
  field(CALC, "(A=1)?0:1")
  field(OOPT, "Every Time")
  field(OUT, "$(P):Busy.VAL PP")
I think only one callback can be queued though.
Cheers,
Matt
On Mar 11, 2015, at 4:42 PM, Benjamin Franksen <[email protected]> wrote:
> I guess the idea is to make a record type that can be processed multiple times
> and fire the put callback only if specific conditions are met, i.e. some
> action (involving perhaps more than one record) have finished. Something like
> the motor record.
> This can indeed be done with a busyRecord and asynchronous out links, but
> depending on what exactly is the desired functionality can be difficult to get
> right. I can try and dig out the database I once designed for that purpose.
> Cheers
> Ben
> Am Mittwoch, 11. März 2015, 19:01:12 schrieb Mooney, Tim M.:
>> Hi Dehong,
>> I don't understand.  All the EPICS records I've used behave correctly when
>> written to by a ca_put_callback, whether they use synchronous or
>> asynchronous device support.  Are you writing a new record type, or trying
>> to get asynchronous device support to work with an existing record type, or
>> what?
>> Tim Mooney ([email protected]) (630)252-5417
>> Software Services Group (www.aps.anl.gov)
>> Advanced Photon Source, Argonne National Lab
>> ________________________________
>> From: [email protected] [[email protected]] on
>> behalf of Zhang, Dehong [[email protected]] Sent: Wednesday, March
>> 11, 2015 1:48 PM
>> To: [email protected]
>> Subject: Please help with "caput -c"
>> Hi Friends,
>> I am trying to implement an asynchronous record, would like to support
>> this "put callback" feature.  From the documentation, it seems I have to do
>> the following:
>> 1. set "pp(TRUE)" for the field the user is going to "caput"
>> 2. make sure only call "recGblFwdLink" (within "process") when the action is
>>    finished, or use a BUSY record in the end of the FLNK chain such that it
>>    is "DONE" only when the action is finished.  -- during this process the
>> PACT
>>    field of the original record can go up and down.
>> I have been playing with all these combinations, and by adding "-w **" after
>> the "caput -c", am getting inconsistent and unreliable results -- it either
>> does
>> not work - calls back immediately, or waits unnecessarily long then calls
>> back.
>> It rarely calls back right after the original record finishes processing and
>> declares
>> the action is finished.  Guess I missed something.  Please spare a few
>> moments
>> and advice on what exactly I need to do.
>> (We use 3.14.12-0.4.0, on linux machines).
>> Thank you very much, Best regards,
>> Dehong
> "There are two ways of constructing a software design: One way is to
> make it so simple that there are obviously no deficiencies and the other
> way is to make it so complicated that there are no obvious deficiencies.
> The first method is far more difficult."   ― C.A.R. Hoare
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Please help with "caput -c" Zhang, Dehong
RE: Please help with "caput -c" Mooney, Tim M.
Re: Please help with "caput -c" Benjamin Franksen
Prev: Re: Please help with "caput -c" Benjamin Franksen
Next: ioc sscan? 梁雅翔
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
