Hi Anton,
Here it SLAC we are heavy EDM users.
Time to checkout caQtDM :)
I will also want to give your converter tool a try: "edl2ui"
Any new updates on the conversion table?
http://www.aps.anl.gov/epics/tech-talk/2015/msg00137.php
But, I am having trouble building :(
I am trying to build the caQtDM for RHEL6 x86_64
I am also attempting to build on Fedora 21 x86_64
I get the same compile error message for "qwt_thermo_marker.cpp"
RHEL6 ==>
caQtDM Version: 3.8.10
qmake -version
QMake version 2.01a
Using Qt version 4.6.2 in /usr/lib64
qt-devel-4.6.2-28.el6_5.x86_64
QWT VERSION: qwt-6.1.0
QtDesigner Version 4.6.2
/usr/include/QtDesigner
Compile Error Below:
g++ -c -m64 -pipe -g -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -Wall -W -D_REENTRANT -fPIC -DIO_OPTIMIZED_FOR_TABWIDGETS -DQT_NO_DEBUG_OUTPUT -DQT_NO_DEBUG -DQT_PLUGIN -DQT_SCRIPT_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQDESIGNER_EXPORT_WIDGETS -I/usr/lib64/qt4/mkspecs/linux-g++-64 -I. -I/usr/include/QtUiTools -I/usr/include/QtDesigner -I/usr/include/QtCore -I/usr/include/QtGui -I/usr/include/QtXml -I/usr/include/QtScript -I/usr/include -Isrc -I/afs/slac/g/lcls/package/qwt-6.1.0/include -Imoc -o obj/moc_leftclick_with_modifiers_eater.o moc/moc_leftclick_with_modifiers_eater.cpp
In file included from src/qwt_thermo_marker.cpp:42:
src/qwt_thermo_marker.h:111: warning: direct base 'QWidget' inaccessible in 'QwtThermoMarker' due to ambiguity
src/qwt_thermo_marker.cpp: In function 'bool qwtIsLogarithmic(const QwtThermoMarker*)':
src/qwt_thermo_marker.cpp:46: error: 'QwtScaleTransformation' has not been declared
src/qwt_thermo_marker.cpp:46: error: expected initializer before 'scaleType'
src/qwt_thermo_marker.cpp:49: error: 'scaleType' was not declared in this scope
src/qwt_thermo_marker.cpp:49: error: 'QwtScaleTransformation' has not been declared
src/qwt_thermo_marker.cpp: At global scope:
Fedora 21 ==>
qmake -version
QMake version 2.01a
Using Qt version 4.8.6 in /usr/lib64
qt-devel-4.8.6-18.fc21.x86_64
QWT VERSION: qwt-6.1.2-1.fc21.x86_64
QtDesigner Version 4.8.6
g++ -c -pipe -g -O2 -g -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -O2 -Wall -W -D_REENTRANT -fPIC -DIO_OPTIMIZED_FOR_TABWIDGETS -DQT_NO_DEBUG_OUTPUT -DQT_NO_DEBUG -DQT_PLUGIN -DQT_SCRIPT_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQDESIGNER_EXPORT_WIDGETS -DQWT_DLL -DQT_SHARED -I/usr/lib64/qt4/mkspecs/linux-g++ -I. -I/usr/include/QtUiTools -I/usr/include/QtDesigner -I/usr/include/QtCore -I/usr/include/QtGui -I/usr/include/QtXml -I/usr/include/QtScript -I/usr/include -Isrc -I/usr/include/qwt -Imoc -I/usr/include/qwt -o obj/moc_camenu.o moc/moc_camenu.cpp
In file included from src/qwt_thermo_marker.cpp:42:0:
src/qwt_thermo_marker.h:110:20: warning: direct base ‘QWidget’ inaccessible in ‘QwtThermoMarker’ due to ambiguity
class QTCON_EXPORT QwtThermoMarker: public QWidget, public QwtAbstractScale
src/qwt_thermo_marker.cpp: In function ‘bool qwtIsLogarithmic(const QwtThermoMarker*)’:
src/qwt_thermo_marker.cpp:46:11: error: ‘QwtScaleTransformation’ does not name a type
const QwtScaleTransformation::Type scaleType =
src/qwt_thermo_marker.cpp:49:14: error: ‘scaleType’ was not declared in this scope
return ( scaleType == QwtScaleTransformation::Log10 );
Cheers,
Ernesto
- Re: caQtDM Compile Error: qwt_thermo_marker.cpp Ebner Simon Gregor (PSI)
RE: Problem with libhdf5.a when installling areaDetector-2-1 Mark Rivers
Re: caQtDM Compile Error: qwt_thermo_marker.cpp Williams Jr., Ernest L.
<2015>
RE: Problem with libhdf5.a when installling areaDetector-2-1 Cristian Savlovschi
<2015>
