1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: cross compiling EPICS Base fails
To: [email protected]
Date: Fri, 06 Mar 2015 16:32:24 +0100
Hey Lukas,
I guess your definition of GNU_DIR is incorrect.
The EPICS builod system searches for the cross-compiler includes in
$GNU_DIR/include but the path you have given would be
$GNU_DIR/../../include
Comparing your setup with mine (I'm using crosstool-ng) the
correct setting should be
GNU_DIR = /opt/oecore-x86_64/sysroots/x86_64-angstromsdk-linux
Hope this helps.
  Florian
On 03/06/2015 01:40 PM, Lukas Böhm wrote:
I am having some trouble while cross compiling EPICS Base for linux-arm on my linux-x86_64 machine and my cross toolchain from Openembedded.
Build crashes at :
make[3]: Verzeichnis »/home/lb/src/EPICS_test/base-3.14.12.4/src/libCom/O.linux-x86_64« wird verlassen
    make -C O.linux-arm -f ../Makefile TOP=../../.. T_A=linux-arm install
make[3]: Verzeichnis »/home/lb/src/EPICS_test/base-3.14.12.4/src/libCom/O.linux-arm« wird betreten
/opt/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/bin/arm-angstrom-linux-gnueabi-gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/ti
mer -I.
./../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include -I/opt/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi/include ../../../src/libCom/bucketLib/bucketLib.c
../../../src/libCom/bucketLib/bucketLib.c:19:19: fatal error: stdio.h: No such file or directory
 #include <stdio.h>
My configurations:
Under configure dir I set in CONFIG_SITE file:
    CROSS_COMPILER_TARGET_ARCHS=linux-arm
    CROSS_COMPILER_HOST_ARCHS=linux-x86_64
Under configure/os I copied CONFIG_SITE.linux-x86.linux-arm to CONFIG_SITE.linux-x86_64.linux-arm
and set there:
    GNU_TARGET = arm-angstrom-linux-gnueabi
GNU_DIR = /opt/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi
as this is the folder containing toolchain binaries as arm-angstrom-linux-gnueabi-gcc and so on. Additionally I had to make a soft-link "bin" inside this directory pointing to this directory for EPICS to find the binaries.
The missing stdio.h is under /opt/oecore-x86_64/sysroots/armv7at2hf-vfp-neon-angstrom-linux-gnueabi/usr/include .
Hopefully someone could help.
Thanks
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz /           |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36         |
| D-55128 Mainz                        |
| Office: SB1 / 00-321                 |
| Phone:  (+49)6131 / 39-29605         |
cross compiling EPICS Base fails Lukas Böhm
Prev: Problem with libhdf5.a when installling areaDetector-2-1 Cristian Savlovschi
Next: RE: Problem with libhdf5.a when installling areaDetector-2-1 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: cross compiling EPICS Base fails Lukas Böhm
Next: Problem with libhdf5.a when installling areaDetector-2-1 Cristian Savlovschi
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
