1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: cross compiling EPICS Base fails
To: [email protected]
Date: Fri, 06 Mar 2015 13:40:13 +0100
I am having some trouble while cross compiling EPICS Base for linux-arm on my linux-x86_64 machine and my cross toolchain from Openembedded.
Build crashes at :
make[3]: Verzeichnis »/home/lb/src/EPICS_test/base-3.14.12.4/src/libCom/O.linux-x86_64« wird verlassen
	make -C O.linux-arm -f ../Makefile TOP=../../.. T_A=linux-arm install
make[3]: Verzeichnis »/home/lb/src/EPICS_test/base-3.14.12.4/src/libCom/O.linux-arm« wird betreten
	/opt/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/bin/arm-angstrom-linux-gnueabi-gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500            -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall          -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/ti
mer -I.
./../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/opt/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi/include ../../../src/libCom/bucketLib/bucketLib.c
../../../src/libCom/bucketLib/bucketLib.c:19:19: fatal error: stdio.h: No such file or directory
 #include <stdio.h>
My configurations:
Under configure dir I set in CONFIG_SITE file:
	CROSS_COMPILER_TARGET_ARCHS=linux-arm
	CROSS_COMPILER_HOST_ARCHS=linux-x86_64
Under configure/os I copied CONFIG_SITE.linux-x86.linux-arm to CONFIG_SITE.linux-x86_64.linux-arm
and set there:
	GNU_TARGET = arm-angstrom-linux-gnueabi
GNU_DIR = /opt/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi
as this is the folder containing toolchain binaries as arm-angstrom-linux-gnueabi-gcc and so on. Additionally I had to make a soft-link "bin" inside this directory pointing to this directory for EPICS to find the binaries.
The missing stdio.h is under /opt/oecore-x86_64/sysroots/armv7at2hf-vfp-neon-angstrom-linux-gnueabi/usr/include .
Hopefully someone could help.
Thanks
Lukas Böhm                       fon:  ++49 351 26996-0
iseg Spezialelektronik GmbH      fax:  ++49 351 26996-21
Bautzner Landstr. 23             mail: [email protected]
D-01454 Radeberg OT Rossendorf   web:  www.iseg-hv.de
Re: cross compiling EPICS Base fails Florian Feldbauer
Prev: RE: asyn R4.26 Mark Rivers
Next: Problem with libhdf5.a when installling areaDetector-2-1 Cristian Savlovschi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: IOC shell message for waveform record Mark Rivers
Next: Re: cross compiling EPICS Base fails Florian Feldbauer
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
