Hi Stuart,
I was able to reproduce your problem. Your screen shot shows the problem. You are in "Stream" mode but you have set NumCapture to 0. Under those conditions it crashed for me with a similar error. If you are in Stream mode you need to set NumCapture to a positive number, i.e. the number of images you want to save before closing the file.
Please try the following:
- In Stream mode set NumCapture to 5 and then press Capture/Start. It should save a single file with 5 images.
- Change to Single mode and then press Save to save a single frame.
See if both of these work for you, they do for me.
Admittedly it should not crash under the condition where NumCapture=0, so we will work on that.
This is the error I got:
2015/03/04 20:51:31.465 NDPluginFile:writeFileBase Error writing file, status=3
HDF5-DIAG: Error detected in HDF5 (1.8.7) thread 0:
#000: H5Dio.c line 245 in H5Dwrite(): file selection+offset not within extent
major: Dataspace
minor: Out of range
Sent: Wednesday, March 04, 2015 7:15 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re: Problem with HDF5 plugin for areaDetector
Hi Mark,
Tried what you suggested. I aligned by forked master with the latest from ADCore (See log below). After a `make clean` and `make` I still get the error. I have also attached a screenshot of the plugin (sorry for the png) to show the settings. Basically from this point on, starting capture to start makes it go boom. I am using the default packages from debian (see below). I couldn’t get the other branch to compile on the head, but haven’t looked fully as to why not.
Stuart
[cid:CD232CDB-CDF8-486C-B20B-734D3D3846EC]
commit bbed9e7b1e0844413078e06806653f2744ce5e60
Author: Stuart B. Wilkins <[email protected]<mailto:[email protected]>>
Date: Wed Mar 4 20:04:20 2015 -0500
Updates for CSX
commit 5a09bfab5bfa48303aef8dfd407be131be205f45
Merge: eeafcbc 4cd14fe
Author: Mark Rivers <[email protected]<mailto:[email protected]>>
Date: Wed Mar 4 18:44:29 2015 -0600
Merge branch 'circ_buff_trigger'
commit eeafcbcb556bbe35ffde736dbf64ed919aff2bfc
Merge: ea0a72e d75877e
Date: Wed Mar 4 18:42:08 2015 -0600
Merge pull request #70 from timmmooney/master
display-file translations 3/3/2015
commit 4cd14fe798b0909ae73d6e6d226e950303ea9c69
Date: Wed Mar 4 17:11:24 2015 -0600
Removed duplicate record
ii hdf5-helpers 1.8.8-9+b1 amd64 Hierarchical Data Format 5 (HDF5) - Helper tools
ii hdf5-tools 1.8.8-9+b1 amd64 Hierarchical Data Format 5 (HDF5) - Runtime tools
ii libhdf4-0 4.2r4-13 amd64 Hierarchical Data Format 4 library -- library package
ii libhdf4-0-alt 4.2r4-13 amd64 Hierarchical Data Format 4 library -- library package
ii libhdf5-7 1.8.8-9+b1 amd64 Hierarchical Data Format 5 (HDF5) - runtime files - serial version
ii libhdf5-dev 1.8.8-9+b1 amd64 Hierarchical Data Format 5 (HDF5) - development files - serial version
ii libhdf5-serial-dev 1.8.8-9+b1 amd64 Hierarchical Data Format 5 (HDF5) - development files - transitionnal package
ii python-h5py 2.0.1-2+b1 amd64 h5py is a general-purpose Python interface to hdf5
- RE: Problem with HDF5 plugin for areaDetector Mark Rivers
- Problem with HDF5 plugin for areaDetector Wilkins, Stuart
- Re: Problem with HDF5 plugin for areaDetector Wilkins, Stuart
Re: How to handle out-of-index of MBBO/MBBI? Jeong Han Lee
RE: Is there a way to view the type of flags associated with a link Abadie Lana
<2015>
<2015>
