Once I add only the IVOA field into mbbo as
field(IVOA, "Don't drive outputs")
The case 2) error wasn't printed out in the IOC console anymore. The
UNSV field doesn't show any difference so far. I will investigate them
later.
By the way, in the EPICS wiki,
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Common, I see
three possible selections in Invalid Alarm Output Action section are
CONTINUE, NO_OUTPUT, and OUTPUT_IVOV.
IOC returns the following message:
Can't set "ECR11-Diag:FC01:SetADRate.IVOA" to "NO_OUTPUT"
Error at or before ")" in file "db/devkeithley6514.db" line 522
However, Michael and Chris told me to use "Don't drive outputs" and I
found three possible selections such as "Continue normally", "Don't
drive outputs", and "Set output to IVOV" in menuIvoa.dbd. No error
messages I can see in the IOC. I guess the wiki is out-of-date. Am I
correct?
Thank you, Michael and Chris!
Han
On 03/04/2015 11:13 PM, Michael Davidsaver wrote:
On 03/04/2015 12:12 AM, Jeong Han Lee wrote:
Here is my question:
How to ignore out-of-range index in mbbo or mbbi in both cases?
Where I have to implement it?
You should to investigate the UNSV and IVOA fields of mbboRecord. The
combination of UNSV=INVALID and IVOA="Don't drive outputs" might be
closer to what you want.
Jeong Han Lee, Dr.rer.nat.
Accelerator Systems Division
Rare Isotope Science Project
Institute for Basic Science
Daejeon, South Korea
tel : +82-42-878-8733
fax : +82-42-878-8799
- Re: How to handle out-of-index of MBBO/MBBI? Andrew Johnson
- How to handle out-of-index of MBBO/MBBI? Jeong Han Lee
- Re: How to handle out-of-index of MBBO/MBBI? Michael Davidsaver
Re: error on the IOC shell for asyn driver Rod Nussbaumer
RE: Problem with HDF5 plugin for areaDetector Mark Rivers
<2015>
<2015>
