1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: seq 2-2-1 cannot build static libraries
Date: Wed, 4 Mar 2015 21:04:22 +0100
I received two bug reports about this problem and can also reproduce it
myself, setting (in base-3.15.1) SHARED_LIBRARIES=NO and
STATIC_BUILD=YES. This is the first error I get:
/usr/bin/g++ -o snc -Wl,-Bstatic -
L/net/csr/srv/projects/ctl/franksen/epics/support/seq/branch-2-2/lib/linux-
x86 -
L/net/csr/srv/projects/ctl/franksen/epics/base/base-3.15.1/lib/linux-x86
-Wl,-
rpath,/net/csr/srv/projects/ctl/franksen/epics/support/seq/branch-2-2/lib/linux-
x86 -Wl,-
rpath,/net/csr/srv/projects/ctl/franksen/epics/base/base-3.15.1/lib/linux-
x86          -rdynamic -m32            lexer.o snl.o main.o node.o
var_types.o analysis.o gen_code.o gen_ss_code.o gen_tables.o sym_table.o
builtin.o type_check.o    -ldbRecStd -ldbCore -lca -lCom -lCom -lseq -
Wl,-Bdynamic  -lpthread   -lreadline -lm -lrt -ldl -lgcc
x86/libseq.a(seq_main.o): In function `init_sprog':
/net/csr/srv/projects/ctl/franksen/epics/support/seq/branch-2-2/src/seq/O.linux-
x86/../seq_main.c:228: undefined reference to `freeListInitPvt'
I am stupefied by this. This is the relevant part of the Makefile:
#  seq library
LIBRARY = seq
seq_LIBS = pv Com
seq_SRCS += seq_main.c
seq_SRCS += ... etc etc ...
Nothing special here! Why does this work for shared but not for static
libraries?
Any kind of hint as to what I might be missing would be appreciated.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
solved: seq 2-2-1 cannot build static libraries Benjamin Franksen
Re: sseq 2-2-1 issue/bug Benjamin Franksen
Re: sseq 2-2-1 issue/bug Matthew D. Moore
Prev: EDM: seeking larger menus and text editing widgets jon
Next: solved: seq 2-2-1 cannot build static libraries Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: sseq 2-2-1 issue/bug Matthew D. Moore
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
