Since this is a pcaspy only bug, I created the report in the project issue tracker.
https://code.google.com/p/pcaspy/issues/detail?id=14
Thanks for the detective work to reveal the bug.
Best
Xiaoqiang
> On 03 Mar 2015, at 18:54, Jameson Graef Rollins <[email protected]> wrote:
> On Tue, Mar 03 2015, "Kasemir, Kay" <[email protected]> wrote:
>> On Mar 3, 2015, at 12:19 PM, Andrew Johnson <[email protected]>
>> wrote:
>>> On 03/03/2015 11:04 AM, Kasemir, Kay wrote:
>>>> Until the PV is initialized, I get the same
>>>> No conversion between src & dest types no conversion between event
>>>> app type=16 and DBR type=18 Element count=60
>>>> error.
>>> The implication is that pcaspy is presenting an uninitialized channel's
>>> value to the cas as some type which gdd can't convert into to an array
>>> of chars. The answer may be as simple as always initializing the value
>>> of a string channel to be an empty string.
>> .. which I just found can be done like this:
>> self.setParam('ThatPV', [ 0 ])
>> That seems to work for clients that look for a long string, since they end on the first '\0'.
> Interesting. I can confirm this works as well. In fact, just setting
> the initial 'value' to [0] in the database definition does the trick as
> well:
> 'STR': {
> 'type': 'char',
> 'count': 60,
> 'value': [0],
> Thanks for the sleuthing, Kay. Maybe we can put together a patch that
> changes how these records are initialized inside of pcaspy.
> I just realized that camonitor is showing worse behavior than MEDM in
> regards to these improperly initialized records; it just hangs with no
> output at all until a valid value has been written to the array.
> jamie.
- Re: "No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
- "No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
- Re: "No conversion between src & dest" warning with pcaspy Andrew Johnson
- Re: "No conversion between src & dest" warning with pcaspy Kasemir, Kay
error on the IOC shell for asyn driver Vishnu Patel
<2015>
<2015>
