1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: "No conversion between src & dest" warning with pcaspy
To: <[email protected]>
Date: Tue, 3 Mar 2015 11:19:13 -0600
On 03/03/2015 11:04 AM, Kasemir, Kay wrote:
> Until the PV is initialized, I get the same
>   No conversion between src & dest types no conversion between event
>   app type=16 and DBR type=18 Element count=60
> error.
The implication is that pcaspy is presenting an uninitialized channel's
value to the cas as some type which gdd can't convert into to an array
of chars. The answer may be as simple as always initializing the value
of a string channel to be an empty string.
- Andrew
Doctorow's Law: Anytime someone puts a lock on something you own,
    against your wishes, and doesn't give you the key, they're
    not doing it for your benefit.
Re: "No conversion between src & dest" warning with pcaspy Kasemir, Kay
Re: "No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
Re: "No conversion between src & dest" warning with pcaspy Andrew Johnson
Prev: Re: "No conversion between src & dest" warning with pcaspy Kasemir, Kay
Next: Re: "No conversion between src & dest" warning with pcaspy Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
