1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: problem with pointGreyApp.exe using AD 2-1
Date: Wed, 25 Feb 2015 14:58:24 -0500
Hello all,
Thank you for all your help. Adding the dll paths in the batch file fixed it. Works like a charm.
Best,
Ali
Alireza Panna
University of Maryland, College Park
On Wed, Feb 25, 2015 at 2:32 PM, Zachary Brown <[email protected]> wrote:
Alireza,
There should be a batch file dllPaths.bat that adds base/synApps/areaDetector /bin/ folders to your PATH.  I call this before running the st.cmd.  I can send you mine if you need it.
-ZB
On Wed, Feb 25, 2015 at 2:03 PM, Alireza Panna <[email protected]> wrote:
Hello tech-talkers,
I am having trouble running the pointGreyApp executable ( I did not get errors during compile time of ADPointGrey). The error says that pointGrey.dll is missing, however, I see that it is present in C:\Epics\support\areaDetector-2-1\ADPointGrey\bin\windows-x64
Maybe I missed some path definition but I can't figure it out. Below is my  envPath:
epicsEnvSet("ARCH","windows-x64")
epicsEnvSet("IOC","iocPointGrey")
epicsEnvSet("TOP","C:/Epics/support/areaDetector-2-1/ADPointGrey/iocs/pointGreyIOC")
epicsEnvSet("ADPOINTGREY","C:/Epics/support/areaDetector-2-1/ADPointGrey")
epicsEnvSet("SUPPORT","C:/Epics/support")
epicsEnvSet("AREA_DETECTOR","C:/Epics/support/areaDetector-2-1")
epicsEnvSet("EPICS_BASE","C:/Epics/base-3.14.12.4")
epicsEnvSet("ASYN","C:/Epics/support/asyn-4-26")
epicsEnvSet("ADCORE","C:/Epics/support/areaDetector-2-1/ADCore")
epicsEnvSet("CALC","C:/Epics/support/calc-3-4-2")
#epicsEnvSet("BUSY","C:/Epics/support/busy-1-6")
epicsEnvSet("SSCAN","C:/Epics/support/sscan-2-10")
epicsEnvSet("AUTOSAVE","C:/Epics/support/autosave-5-5")
I have the flycapture viewer installed along with their sdk as well. Epics base and Area detector are compiled dynamically (using MS Visual Studio 12).
Any help will be appreciated.
Alireza Panna
problem with pointGreyApp.exe using AD 2-1 Alireza Panna
Re: problem with pointGreyApp.exe using AD 2-1 Zachary Brown
Prev: Re: problem with pointGreyApp.exe using AD 2-1 Zachary Brown
Next: Error in compiling areaDetector GONG Yu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
