Hi Alireza,
The problem is that you have built pointgrayApp as a dynamic executable, so it requires being able to find not only pointGrey.dll, but also all of the other DLLs in EPICS
base and synApps.
If you defined ARCH=windows-x64 in ADPointGrey/iocs/iocPointGrey/iocBoot/iocPointGrey/Makefile, then that directory should contain a file called dllPath.bat. If not, edit
the Makefile to set ARCH=windows-x64 and run “make clean”, “make”, which will create dllPath.bat. You need to execute that batch file once per Windows session before executing the pointGreyApp application. That batch file will define your PATH so it will
find all of the required DLLs. From the iocPointGrey directory:
.\dllPath.bat
..\..\bin\windows-x64\pointGreyApp st.cmd
Let me know if you have problems or questions.
I am having trouble running the pointGreyApp executable ( I did not get errors during compile time of ADPointGrey). The error says that pointGrey.dll is missing, however, I see
that it is present in C:\Epics\support\areaDetector-2-1\ADPointGrey\bin\windows-x64
Maybe I missed some path definition but I can't figure it out. Below is my envPath:
epicsEnvSet("ARCH","windows-x64")
epicsEnvSet("IOC","iocPointGrey")
epicsEnvSet("TOP","C:/Epics/support/areaDetector-2-1/ADPointGrey/iocs/pointGreyIOC")
epicsEnvSet("ADPOINTGREY","C:/Epics/support/areaDetector-2-1/ADPointGrey")
epicsEnvSet("SUPPORT","C:/Epics/support")
epicsEnvSet("AREA_DETECTOR","C:/Epics/support/areaDetector-2-1")
epicsEnvSet("EPICS_BASE","C:/Epics/base-3.14.12.4")
epicsEnvSet("ASYN","C:/Epics/support/asyn-4-26")
epicsEnvSet("ADCORE","C:/Epics/support/areaDetector-2-1/ADCore")
epicsEnvSet("CALC","C:/Epics/support/calc-3-4-2")
#epicsEnvSet("BUSY","C:/Epics/support/busy-1-6")
epicsEnvSet("SSCAN","C:/Epics/support/sscan-2-10")
epicsEnvSet("AUTOSAVE","C:/Epics/support/autosave-5-5")
I have the flycapture viewer installed along with their sdk as well. Epics base and Area detector are compiled dynamically (using MS Visual Studio 12).
Any help will be appreciated.
University of Maryland, College Park
- problem with pointGreyApp.exe using AD 2-1 Alireza Panna
Re: problem with pointGreyApp.exe using AD 2-1 Zachary Brown
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
