1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Using the EPICS Build/Make system to build kernel modules for linux
Date: Tue, 24 Feb 2015 17:27:48 -0600
On 2/24/15 11:43 AM, Jameson Graef Rollins wrote:
> That said, my packaging experience leads me to strongly prefer build
> systems that work in "standard" ways, and don't for instance require
> in-tree builds for linking applications, which EPICS currently
> requires (modulo the packaging ninjitsu accomplished by the EPICS
> Debian packagers).
Hi, Jamie.
By this, do you mean you wish for DESTDIR [1] support?  If so, I
strongly agree that that would be a *big* improvement.  BTW, there was a
tech-talk mailing list thread in October 2014 that touched on this [2].
Lewis
[1] http://www.gnu.org/prep/standards/html_node/DESTDIR.html
[2] http://www.aps.anl.gov/epics/tech-talk/2014/msg01500.php
Using the EPICS Build/Make system to build kernel modules for linux Williams Jr., Ernest L.
Re: Using the EPICS Build/Make system to build kernel modules for linux Jameson Graef Rollins
RE: Using the EPICS Build/Make system to build kernel modules for linux Williams Jr., Ernest L.
RE: Using the EPICS Build/Make system to build kernel modules for linux Jameson Graef Rollins
Prev: RE: multiple interrupt callback for waveform record Mark Rivers
Next: RE: Using the EPICS Build/Make system to build kernel modules for linux Williams Jr., Ernest L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Using the EPICS Build/Make system to build kernel modules for linux Jameson Graef Rollins
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
