My bad for not mentioning that I have read the pdf. And I did clone and import https://github.com/ControlSystemStudio/maven-osgi-bundles.git and https://github.com/ControlSystemStudio/cs-studio-thirdparty.git as well. Although I did not clone and import org.csstudio.product.git. I did not mention it because I was in a state of total confusion (which I have to admit is my usual state whenever I try to build cs-studio).
I must also admit that I always have tones and tones of errors when I import all the plugins into eclipse (3.2.x and eariler). I just hope they are not the plugins I need. Because there is no way to tell exactly which plugins you actually need (and of course those plugins will require other plugins, and so on) and it’s too slow to import all the plugins one by one. So I usually import them all and ignore the errors. With this new maven build on master, I have to import all the plugins anyway. Then I end up with thousands of errors. Does anyone else have this problem or is it just me?
Anyway, I digress. I dug around the errors and found the following:
Project 'org.csstudio.platform.libs.epics' is missing required library: 'lib/caj-1.1.13.jar' org.csstudio.platform.libs.epics Build path Build Path Problem
Project 'org.csstudio.platform.libs.epics' is missing required library: 'lib/jca-2.3.6.jar' org.csstudio.platform.libs.epics Build path Build Path Problem
Could these be the cause for not finding epics plugins?
Xinyu
On 24 Feb 2015, at 9:44 pm, Jani Hakala <[email protected]> wrote:
> <[email protected]> writes:
>> Hi,
>> I’m trying to get cs-studio to work with maven and eclipse:
>> $ git clone https://github.com/ControlSystemStudio/cs-studio.git
> You should probably follow the instructions in
> http://cs-studio.sourceforge.net/docbook/ch04.html
> "Chapter 4. Compiling, Running, Debugging CSS"
> pdf-version is available at
> http://cs-studio.sourceforge.net/docbook/css_book.pdf
> The instructions mention other repositories to clone,
> https://github.com/ControlSystemStudio/org.csstudio.product.git
> Jani Hakala
Xinyu WU
ASKAP Computing
Australia Telescope National Facility
CSIRO Astronomy and Space Science
phone: +61 2 9372 4727
postal: PO Box 76 Epping, NSW. 1710
- Importing cs-studio into eclipse Xinyu.Wu
- Re: Importing cs-studio into eclipse Jani Hakala
Begginer with EPICSv4 Ricardo Herrero
Re: Importing cs-studio into eclipse Xinyu.Wu
<2015>
<2015>
