Hello all,
After many trials, it seems that I have installed edm-1-12-98 successfully
on my PC (linux-x86), but when I run edm command, I get following error
message:-
rahul@RahulJain-PC:~$ edm
X error: code=3, msg: BadWindow (invalid Window parameter)
Error: No realize class procedure defined
Please suggest me how to fix this error. I have used following
configurations before running the edm command.
export EPICS_BASE=/opt/myepics/base
export EPICS_HOST_ARCH=linux-x86
export PATH=$PATH:$EPICS_BASE/bin/$EPICS_HOST_ARCH
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_ARCH
export EPICS_EXTENSIONS=/opt/myepics/extensions
export PATH=$PATH:$EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
export
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH
cd $HOME
mkdir edm
mkdir edm/prefs
export EDMOBJECTS=$HOME/edm/prefs
export EDMDATAFILES=$HOME/edm
export EDMFILES=$HOME/edm/prefs
export EDMPVOBJECTS=$HOME/edm/prefs
export EDMHELPFILES=/opt/myepics/extensions/src/edm/helpFiles
edm -add /opt/myepics/extensions/lib/linux-x86/libEdmBase.so
edm -add
/opt/myepics/extensions/lib/linux-x86/libcfcaa62e-8199-11d3-a77f-00104b8742df.so
edm -add
/opt/myepics/extensions/lib/linux-x86/libcf322683-513e-4570-a44b-7cdd7cae0de5.so
edm -add
/opt/myepics/extensions/lib/linux-x86/lib7e1b4e6f-239d-4650-95e6-a040d41ba633.so
edm -add
/opt/myepics/extensions/lib/linux-x86/lib57d79238-2924-420b-ba67-dfbecdf03fcd.so
edm -addpv /opt/myepics/extensions/lib/linux-x86/libEpics.so
edm -addpv /opt/myepics/extensions/lib/linux-x86/libCalc.so
edm -addpv /opt/myepics/extensions/lib/linux-x86/libLoc.so
edm -addpv /opt/myepics/extensions/lib/linux-x86/libLog.so
cd $HOME/edm/prefs
cp /opt/myepics/extensions/src/edm/setup/calc.list $HOME/edm/prefs
cp /opt/myepics/extensions/src/edm/setup/colors.list $HOME/edm/prefs
cp /opt/myepics/extensions/src/edm/setup/fonts.list $HOME/edm/prefs
cp /opt/myepics/extensions/src/edm/edmMain/edmPrintDef $HOME/edm/prefs
With best regards
Rahul Jain
BDS/ACBDD
RRCAT, Indore
Ph.:0731-244-2555
Mob.:08989006799
Importing cs-studio into eclipse Xinyu.Wu
Re: using EPICS code with HTTP port Jack
<2015>
RE: Importing cs-studio into eclipse Richard Fearn
"epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
<2015>
