1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: seq-2.2.1 fails to build tests with VS 2010
To: "Tagger, Jueri" <[email protected]>, <[email protected]>
Date: Fri, 20 Feb 2015 12:25:13 +0100
On Tuesday 10 February 2015 19:39:59 Tagger, Jueri wrote:
> Hi, Benjamin,
> Tried to build seq-2.2.1 using Visual Studio 2010:
> 1.       The same problem 'unresolved external symbol' problem there
> was a while ago with seq_sync_timeout. Now the unresolved symbols
> are: prim_type_name and prim_type_tag_name. I re-built the seq.dll
> with keywords /EXPORT:prim_type_name /EXPORT:prim_type_tag_name
> added. I remember once the remedy was to declare those as
> epicsShareExtern/epicsShareDef.
I have made a fix for this. Could you try with the latest snapshot,
please? The URL is
http://www-csr.bessy.de/control/SoftDist/sequencer/releases/seq-2-2-snapshot-latest.tar.gz
Cheers
Ben
> 2.       The tests don't build:
> link -nologo /LTCG /incremental:no /opt:ref /release "Ws2_32.lib"
> "Advapi32.lib" "User32.lib" -out:cppComment.exe cppComment.obj
> ..\\..\\..\\lib\\win32-x86\\seq.lib<file:///\\..\..\lib\win32-x86\seq
> .lib>
> ..\\..\\..\\lib\\win32-x86\\pv.lib<file:///\\..\..\lib\win32-x86\pv.l
> ib>
> C:\Users\Public\Documents\EPICS\R3_14_12_4\base-3.14.12.4\\lib\\win32
> -x86\\recIoc.lib
> -x86\\softDevIoc.lib
> -x86\\miscIoc.lib
> -x86\\rsrvIoc.lib
> -x86\\dbtoolsIoc.lib
> -x86\\asIoc.lib
> -x86\\dbIoc.lib
> -x86\\registryIoc.lib
> -x86\\dbStaticIoc.lib
> -x86\\ca.lib
> -x86\\Com.lib LINK : fatal error LNK1561: entry point must be defined
> gnumake[3]: *** [cppComment.exe] Error 1561
> gnumake[3]: Leaving directory
> `C:/Users/Public/Documents/EPICS/R3_14_12_4/modules/soft/seq-2.2.1/te
> st/compiler/O.win32-x86'
> gnumake[2]: *** [install.win32-x86] Error 2
> gnumake[2]: Leaving directory
> st/compiler'
> gnumake[1]: *** [compiler.install] Error 2
> gnumake[1]: Leaving directory
> st'
> gnumake: *** [test.install] Error 2
> Any suggestions?
I have no idea. Maybe someone on tech-talk knows.
As a quick work-around, you can just remove the test directory from the
top-level Makefile.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Prev: RRM offline? Benjamin Franksen
Next: Re: sseq 2-2-1 issue/bug Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: RRM offline? Andrew Johnson
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
