1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Error in EDM-1-12-98 installation
To: Mike Westfall <[email protected]>, Rahul Jain <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 18 Feb 2015 14:40:07 +0000
This is the result of my not updating the png widget to use the latest
library. You may find sources for the older version at
http://ics-web.sns.ornl.gov/edm/docs/show.php?folderId=4.
On 2/18/15, 8:47 AM, "Mike Westfall" <[email protected]> wrote:
>For Ubuntu, I'm guessing you need to do
> > sudo apt-get install libpng-dev
>On 02/18/2015 01:15 AM, Rahul Jain wrote:
>> Hello,
>> I am facing problem in installing edm-1-12-98, although I have already
>> installed the following libraries required for EDM installation on my
>> linux-x86 (ubuntu 14.04) PC.
>> libx11-dev, libxtst-dev, zlib1g-dev giflib-4.1.3,  libungif-4.1.3,
>> libpng-1.2.6rc1-config, libxt-dev, libmotif-dev, x11proto-print-dev,
>> libxmu-headers, libxp-dev, libxmu-dev, libxmu6
>> The error messages, while installing edm-1-12-98 is given as follows:-
>> /usr/bin/g++ -o edm  -L/opt/myepics/base-3.14.12.4/lib/linux-x86
>> -L/opt/myepics/extensions/lib/linux-x86 -L/usr/lib
>> -L/usr/lib/i386-linux-gnu
>> -Wl,-rpath,/opt/myepics/base-3.14.12.4/lib/linux-x86
>> -Wl,-rpath,/opt/myepics/extensions/lib/linux-x86 -Wl,-rpath,/usr/lib
>> -Wl,-rpath,/usr/lib/i386-linux-gnu       -m32  -z combreloc -z lazyload
>>           main.o    -lcfcaa62e-8199-11d3-a77f-00104b8742df
>> -l114135a4-6f6c-11d3-95bc-00104b8742df -lXm -lXmu -lXt -lXp -lXtst -lX11
>> -lca -lCom  -lpthread -ldl
>> /usr/bin/ld: warning: -z lazyload ignored.
>> /usr/lib/libXm.so: undefined reference to `png_read_info@PNG12_0'
>> /usr/lib/i386-linux-gnu/libfreetype.so.6: undefined reference to
>> `png_set_filler@PNG12_0'
>> `png_set_packing@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_set_sig_bytes@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_read_update_info@PNG12_0'
>> `png_set_interlace_handling@PNG12_0'
>>`png_create_read_struct@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_get_rowbytes@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_read_image@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_set_gray_to_rgb@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_get_IHDR@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_get_channels@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_set_strip_16@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_set_expand@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_init_io@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_get_gAMA@PNG12_0'
>> `png_get_io_ptr@PNG12_0'
>> `png_set_palette_to_rgb@PNG12_0'
>> `png_get_error_ptr@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_set_gamma@PNG12_0'
>> `png_destroy_read_struct@PNG12_0' /usr/lib/libXm.so: undefined reference
>> to `png_read_end@PNG12_0'
>> `png_error@PNG12_0'
>> `png_set_read_user_transform_fn@PNG12_0'
>> `png_set_read_fn@PNG12_0'
>>`png_create_info_struct@PNG12_0'
>> `png_set_expand_gray_1_2_4_to_8@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_sig_cmp@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_get_valid@PNG12_0'
>> `png_set_tRNS_to_alpha@PNG12_0'
>> collect2: error: ld returned 1 exit status
>> make[2]: *** [edm] Error 1
>> make[2]: Leaving directory
>> `/opt/myepics/extensions/src/edm/edmMain/O.linux-x86'
>> make[1]: *** [install.linux-x86] Error 2
>> make[1]: Leaving directory `/opt/myepics/extensions/src/edm/edmMain'
>>make:
>> *** [edmMain.install] Error 2
>> Please suggest me, how to fix this error message.
>> Regards
>> Rahul Jain
>Mike Westfall
>Gemini Observatory
>Colina El Pino S/N, Casilla 603
>La Serena, Chile
>Tel: +56 51 2205625
Re: Error in EDM-1-12-98 installation Rahul Jain
Re: Error in EDM-1-12-98 installation Mike Westfall
Prev: Re: Error in EDM-1-12-98 installation Mike Westfall
Next: CSS - Reverse Scale Amien Crombie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Error in EDM-1-12-98 installation Rahul Jain
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
