1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: [CSS] change macro values with script
To: [email protected]
Date: Tue, 17 Feb 2015 17:23:03 +0100 (CET)
Hello to Everyone,
i'm trying to develop a control panel in CSS and i want to change
dynamically the macro substitution in a linking container widget through
a dedicated script. Reading the help documentation, i saw the Macros
Property can be changed with this code:
Javascript:
	importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
	var macroInput = DataUtil.createMacrosInput(true);
	macroInput.put("pv", PVUtil.getString(pvs[0]));
	widget.setPropertyValue("macros", macroInput);
In runtime, i expect the container widget has a new macro called "pv"
with value coming from my variable set as pvs[0] (in my case i'm using a
stringout record), but the only macro available is an element called
"LCID" that changes at every page refresh (for example LCID=LCID_872 of
LCID=LCID_880).
Is there any configuration i'm forgetting to provide the correct set of
macro to my widget?
Thanks in advance for any help!
- Maurizio M.
Prev: asyn R4-26 available Mark Rivers
Next: Possible to set EOS in asyn to match a character plus whatever character follows? Andrew Gomella
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
