1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: can run multiple IOCs on single host?
To: Ralph Lange <[email protected]>, [email protected], [email protected], [email protected]
Cc: [email protected]
Date: Fri, 13 Feb 2015 11:17:07 +0900
Thank you for your help. Your advice was really helpful to me, the problem was solved.
(using multiful hosts and clients on single machine)
The cause of the problem is the firewall. After I stop the firewall service, everything is fine.
Furthermore, in order to use the firewall service, I refer to this page ( EPICS R3.14 Channel Access Reference Manual ).
Best Regards.
JaeRyong
2015-02-11 22:42 GMT+09:00 Ralph Lange <[email protected]>:
On February 11, 2015 2:02:15 PM GMT+01:00, Dirk Zimoch <[email protected]> wrote:
>Since you have EPICS_CA_AUTO_ADDR_LIST=NO and
>EPICS_CA_ADDR_LIST="100.100.10.255 localhost", I suspect that you run
>the IOCs and caget on the same host and 100.100.10.255 is NOT the
>broadcast address of that host. Because in that case caget finds the
>channels at "localhost" and that is a unicast address with the known
>limitations.
I have seen 127.255.255.255 (i.e. the broadcast address of localhost) working. But I also have seen it not working, and I have no insight what exactly is needed in the network stack for it to work.
Worth a try, in any case.
~Ralph
can run multiple IOCs on single host? JaeRyong Seo
Re: can run multiple IOCs on single host? Dirk Zimoch
Re: can run multiple IOCs on single host? Ralph Lange
Prev: RE: Example asyn device support for rs-232 hardware with unsolicited messages (without using stream-device) Mark Rivers
Next: Support for Adam CPWplus 150 Balance Linda.Pratt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host? J. Lewis Muir
Next: multiple overlays with NDPluginOverlay David Michel
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
