1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: can run multiple IOCs on single host?
To: [email protected]
Date: Wed, 11 Feb 2015 14:42:09 +0100
On February 11, 2015 2:02:15 PM GMT+01:00, Dirk Zimoch <[email protected]> wrote:
>Since you have EPICS_CA_AUTO_ADDR_LIST=NO and
>EPICS_CA_ADDR_LIST="100.100.10.255 localhost", I suspect that you run
>the IOCs and caget on the same host and 100.100.10.255 is NOT the
>broadcast address of that host. Because in that case caget finds the
>channels at "localhost" and that is a unicast address with the known
>limitations.
I have seen 127.255.255.255 (i.e. the broadcast address of localhost) working. But I also have seen it not working, and I have no insight what exactly is needed in the network stack for it to work.
Worth a try, in any case.
~Ralph
Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host? Kasemir, Kay
Re: can run multiple IOCs on single host? JaeRyong Seo
Re: can run multiple IOCs on single host? Dirk Zimoch
Prev: Re: using EPICS code with HTTP port Dirk Zimoch
Next: Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host? Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: can run multiple IOCs on single host? Dirk Zimoch
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
