Hi everyone, I am doing some experiments with v4. I have a simple v4 IOC with a single NTNDArray record. On the client side I'm just monitoring it with pvget -m. Everything works fine as I put new values on different fields of my record, except for the 'value' field, which is a union. If I put a new value there (select, reuse, copy data, replace) the monitor doesn't pick up the change. Other fields update automatically after put(). I can fix this by calling the method postPut on the field. Is this the way it's supposed to be? I'm using the latest version of everything from the mercurial repos. Thanks! Bruno
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
