1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Issues with installing the adPython plugin for areaDetector
Cc: EPICS mailing list <[email protected]>
Date: Fri, 6 Feb 2015 10:41:34 +0000
Just for the record, I had to build it somewhere with full permissions (e.g. Desktop) and then move it my /usr/local/epics directory with sudo to get it to work properly.
Cheers
David
Dr. David Michel
Address: 11 Mayfield, Grove, Wantage, OX12 7PU, Oxfordshire
Mobile: 0789 670 98 01 - Home: 01235799753
On 28 January 2015 at 10:57, <[email protected]> wrote:
Well the module is now built and usable, it’s just the example IOC that is failing. In the iocs/example/exampleApp/Db/Makefile there is a PATH:= directive, you could try adding the path to msi in here and see if it helps...
Tom Cobb
Sent: 28 January 2015 10:16
To: Cobb, Tom (DLSLtd,RAL,TEC)
Thanks Tom,
I just deleted the protocol directory... it gets further but now fails at it cannot find msi although it is installed on the PATH...
make[3]: Entering directory `/usr/local/epics/support/adPython/adPython-0-2/iocs/example/exampleApp/Db'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[4]: Entering directory `/usr/local/epics/support/adPython/adPython-0-2/iocs/example/exampleApp/Db/O.linux-x86_64'
echo "../O.Common/example_expanded.db : " >> example_expanded.db.d
echo "example_expanded.db.d: " >> example_expanded.db.d
Inflating database from ../example_expanded.substitutions
msi   -I. -I.. -I../O.Common -I../../../db -I/usr/local/epics/support/areaDetector/current/db -I/usr/local/epics/support/asyn/current/db -I/usr/local/epics/base/db -S../example_expanded.substitutions  > example_expanded.tmp
/bin/sh: 1: msi: not found
On 28 January 2015 at 09:58, <[email protected]> wrote:
I’m a bit confused by the error, but the directory is not required for the build, so you can either delete the adPythonApp/protocol directory, or comment out the line with $(wildcard protocol) in it in adPythonApp/Makefile.
Tom Cobb
From: [email protected] [mailto:[email protected]] On Behalf Of David Michel
Sent: 28 January 2015 09:52
To: EPICS mailing list
Subject: Issues with installing the adPython plugin for areaDetector
Hi All,
I'm currently having issues with installing adPython 0.2 for AreaDetector (R1.9) on Ubuntu (12.04). All I did was 1) download the plugin 2) edit the RELEASE to the relevant path of my system 3), type make at the top level.... but the build just stop when entering the adPythonApp/protocol giving me the error "No rule to make target 'install'"
It's probably something silly, but I cannot find what's wrong.... anyone seen this error before or has experience with installing this plugin?
Many thanks
David
Issues with installing the adPython plugin for areaDetector David Michel
RE: Issues with installing the adPython plugin for areaDetector tom.cobb
Re: Issues with installing the adPython plugin for areaDetector David Michel
Prev: RE: Fetching return value from external program call in StreamDevice Al Honey
Next: Re: Fetching return value from external program call in StreamDevice Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Issues with installing the adPython plugin for areaDetector tom.cobb
Next: trouble building asyn driver on FreeBSD Franklin Fuller
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
