1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Fetching return value from external program call in StreamDevice
To: Christian Pauly <[email protected]>
Cc: "<[email protected]>" <[email protected]>
Date: Thu, 5 Feb 2015 17:05:43 +0000
Since you already have the data in python, you could add the python CA server to your python code, so your python program is like an IOC, directly serving the data via channel access. See https://pcaspy.readthedocs.org
-Kay
On Feb 5, 2015, at 11:58 AM, Christian Pauly <[email protected]>
 wrote:
> Hi
> I want to read out a little pressure sensor, for which i have already a small python script which reads the sensor (via i2c bus) and prints the sensor value to the terminal. Alternatively, i could also give the sensor value as return value upon program exit.
> Now i want to read this sensor inside an EPICS IOC.
> Is it possible, to use StreamDevice for this, by calling the external script / program and evaluating the return value ?
> Maybe using the "exec" statement in the protocol file ?
> Reading the sensor takes some time (500ms), so it would be good to do it asynchronously, without blocking the IOC.
> Or is there any other easy way, without reimplementing all the i2c sensor readout eg inside an ASYN driver in C++ code ?
> Thanks for any hints or help
> Best regards,
> Christian
> Dr. Christian Pauly
> Bergische Universität Wuppertal
> Fachbereich C - Physik
> Gaußstraße 20, D-42119 Wuppertal
> Tel: +49 (0)202 439-2632,
> Fax: +49 (0)202 439-2662
Re: Fetching return value from external program call in StreamDevice Rod Nussbaumer
Fetching return value from external program call in StreamDevice Christian Pauly
Prev: Fetching return value from external program call in StreamDevice Christian Pauly
Next: RE: Fetching return value from external program call in StreamDevice Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Fetching return value from external program call in StreamDevice Rod Nussbaumer
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
