1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Strawberry Perl Make still broken?
To: <[email protected]>
Date: Tue, 3 Feb 2015 01:31:19 +0100
Am Montag, 2. Februar 2015, 17:45:19 schrieb J. Lewis Muir:
> Is the GNU Make that comes with Strawberry Perl still broken?
> I tried building EPICS Base 3.14.12.4, with the Known Problems patches
> applied, on Windows 7 for win32-x86 using the "gmake" included with
> Strawberry Perl 5.20.1.1, and it succeeded.  The "gmake" program
> identified its version as "4.0.90" on the command line when executed
> with the "--version" option.  According to
>   http://www.aps.anl.gov/epics/base/win32.php
> the GNU Make that comes with Strawberry Perl is broken.
Note the page says: "Strawberry Perl comes with GCC, but its GNU Make does not
provide some features needed by the EPICS build system"
That does not mean Strawberry Perl's make is or was "broken". EPICS relies on
lots of extensions that are only available recent versions of gnumake. It
needs at least 3.81, but I am not sure 3.82 is suitable, see the multiple
"WARNING: Backward-incompatibility" on:
https://lists.gnu.org/archive/html/info-gnu/2010-07/msg00023.html
> Is this still
> true, or does the fact that I was able to build EPICS Base successfully
> suggest that perhaps the problem has been fixed?
I guess so, perhaps they fixed those incompatibilities in 4.x. Unfortunately
4.0.90 is not an official release of gnu make (see
http://ftp.gnu.org/gnu/make/). To be sure I would recommend trying to build
3.15 against this version of make and report back if there are problems. You
could also try to build synApps. If that runs through w/o errors you should be
pretty safe.
Cheers
Ben
"Make it so they have to reboot after every typo." -- Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Strawberry Perl Make still broken? J. Lewis Muir
Prev: Re: Remote Controlled Power Distribution Units? Jeong Han Lee
Next: RE: epicsRingPointer.h error C2664: 'delete' : cannot convert parameter Mark S. Engbretson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Strawberry Perl Make still broken? Johnson, Andrew N.
Next: Problem about cross-complie SynApps 吴洪金
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
