1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Strawberry Perl Make still broken?
To: EPICS Tech-Talk <[email protected]>
Date: Mon, 02 Feb 2015 17:45:19 -0600
Hello.
Is the GNU Make that comes with Strawberry Perl still broken?
I tried building EPICS Base 3.14.12.4, with the Known Problems patches
applied, on Windows 7 for win32-x86 using the "gmake" included with
Strawberry Perl 5.20.1.1, and it succeeded.  The "gmake" program
identified its version as "4.0.90" on the command line when executed
with the "--version" option.  According to
  http://www.aps.anl.gov/epics/base/win32.php
the GNU Make that comes with Strawberry Perl is broken.  Is this still
true, or does the fact that I was able to build EPICS Base successfully
suggest that perhaps the problem has been fixed?
Thank you!
Lewis
Re: Strawberry Perl Make still broken? Johnson, Andrew N.
Re: Strawberry Perl Make still broken? Benjamin Franksen
Prev: Re: epicsRingPointer.h error C2664: 'delete' : cannot convert parameter Johnson, Andrew N.
Next: Re: Strawberry Perl Make still broken? Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Read record field in asynDriver Mark Rivers
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
